1950 8n side mount
kenben
PostPosted: Thu Apr 11, 2019 12:17 pm    Post subject: 1950 8n side mount Reply to specific post Reply with quote
Hello,Does any one rebuild carburators??
Dean
PostPosted: Thu Apr 11, 2019 12:52 pm    Post subject: Re: 1950 8n side mount Reply to specific post Reply with quote
I expect that Royse can help you out.
More than likely, he will answer.
Dean
warbaby
PostPosted: Thu Apr 11, 2019 2:28 pm    Post subject: Re: 1950 8n side mount Reply to specific post Reply with quote
Yes, thats why they sell those carburetor rebuild kits!
kenben
PostPosted: Thu Apr 11, 2019 2:52 pm    Post subject: Re: 1950 8n side mount Reply to specific post Reply with quote
Ty
grayrider
PostPosted: Thu Apr 11, 2019 4:15 pm    Post subject: Re: 1950 8n side mount Reply to specific post Reply with quote
It?s easy to do, nothing intimidating at all about these carburetors, a first timer can do one easily...
Royse
PostPosted: Fri Apr 12, 2019 3:46 am    Post subject: Re: 1950 8n side mount Reply to specific post Reply with quote
I rebuild them if you want to hire it done or I can help you do it yourself.
My email is open if you want to talk about it offline.
kenben
PostPosted: Fri Apr 12, 2019 4:41 am    Post subject: Re: 1950 8n side mount Reply to specific post Reply with quote
How do I adjust the carb (2 screws) .
Thank you sir,
Royse
PostPosted: Fri Apr 12, 2019 4:51 am    Post subject: Re: 1950 8n side mount Reply to specific post Reply with quote
As a starting point, turn the main adjustment all the way in until
it is lightly seated, then back it out 1 and 1/2 turns.
The small idle air adjustment is done the same way, but only back
it out 1/2 turn. That should get you running so you can fine tune it.
The idle air adjustment adjusts air, so out gives you more air and
a leaner mixture. In for enrich.
kenben
PostPosted: Fri Apr 12, 2019 5:39 am    Post subject: Re: 1950 8n side mount Reply to specific post Reply with quote
Thank you.I will try again after the rain
stops.
kenben
PostPosted: Thu Apr 18, 2019 8:03 am    Post subject: Re: 1950 8n side mount Reply to specific post Reply with quote
1950 8n side mt. Dist..okay adjusted carb
and she fired up for 3 seconds.I am not
getting gas to flow into carb. It self.Gas
is flowing to it.I checked the brass
fitting screen on carb and its clean.Take
screw out of bottom of carb and no gas
flows out.What did I do when I rebuilt the
carb??Would it be the float sticking??
Thanks,
kenben
PostPosted: Thu Apr 18, 2019 8:07 am    Post subject: Re: 1950 8n side mount Reply to specific post Reply with quote
I backed big screw out hoping fuel would flow,no go.
Royse
PostPosted: Thu Apr 18, 2019 9:50 am    Post subject: Re: 1950 8n side mount Reply to specific post Reply with quote
"Would it be the float sticking??"
Possibly, but it would be more common for the needle to stick.
Sometimes a tap to the side with a screwdriver or hammer handle
will unstick it and let fuel flow into the bowl.
