IH 440 baler
Goto page 1, 2  Next
gotmyfarm!
PostPosted: Tue May 14, 2019 5:23 am    Post subject: IH 440 baler Reply to specific post Reply with quote
Anyone ever owned an IH 440 small square baler? This is the one and only I've ever seen for sale, so I am wondering if it would be hard to find parts for it. Seems rare for around here at least. Anyone know anything about this model?
JOCCO
PostPosted: Tue May 14, 2019 5:29 am    Post subject: Re: IH 440 baler Reply to specific post Reply with quote
Yes me, very good baler There were 430 435 445 and a host of others. Looks like just not popular in your area.
gotmyfarm!
PostPosted: Tue May 14, 2019 5:35 am    Post subject: Re: IH 440 baler Reply to specific post Reply with quote
jocco, ok, thanks! I've been browsing balers for sale since last year and didn't find just the right one. This one looks so nice and matches my tractor!!!!!! Very important to match, you know Very Happy
SVcummins
PostPosted: Tue May 14, 2019 5:43 am    Post subject: Re: IH 440 baler Reply to specific post Reply with quote
Have a 440 all twine I?ve only ran it one year but it?s
been good . Parts are expensive I need a hay dog
for the bale chamber 75$
gotmyfarm!
PostPosted: Tue May 14, 2019 5:50 am    Post subject: Re: IH 440 baler Reply to specific post Reply with quote
SVcummins, oh ok. With the costs for parts then, sounds like it'd be nice to have another junk one just to take parts off of. Sure looks like a nice baler. This one is 3 1/2 hours from me, so need to consider that, too.
Texasmark1
PostPosted: Tue May 14, 2019 6:28 am    Post subject: Re: IH 440 baler Reply to specific post Reply with quote
I had a Case/IH square and as I recall it was a 4 something, may have had the 404 nomenclature. Was used but in perfect operating shape, little wear.
Problem I had was that the pickup tines weren't durable enough and regardless of how I adjusted them, I'd loose about 1 per acre baled. I had JD square
balers and seldom did I break a tine.
VicS
PostPosted: Tue May 14, 2019 7:19 am    Post subject: Re: IH 440 baler Reply to specific post Reply with quote
We have a 430 IHC. I think it has good
capacity, a 440 surely is more. Ours is
wire tie. Never misses a bale if the
splice is small enough to make it through
the needles. Took all the wedges out and
will still make a 80 lb. Bale. We just
want 50 lb.bales. when we got it, could
just bale in low and 2nd. The cam and
bearings were worn out on the pickup.
Repaired this and now can bale in 3rd and
4th. Which is 4.5 mph.
JOCCO
PostPosted: Tue May 14, 2019 8:13 am    Post subject: Re: IH 440 baler Reply to specific post Reply with quote
Not sure what your baling or how much but any of the IH EXCEPT 45 ARE OK (FOR THE MOST PART) THE DEERE 24 214 224 AND 300 SERIES ARE GOOD TOO.
SVcummins
PostPosted: Tue May 14, 2019 8:47 am    Post subject: Re: IH 440 baler Reply to specific post Reply with quote
I found a junk one I?m going to try and buy for parts .
Parts are expensive for anything anymore it seems
like . I?ve ran straw windrows out of a combine with
a 36 foot header so I think they have plenty of
capacity
Paul swpa
PostPosted: Tue May 14, 2019 12:50 pm    Post subject: Re: IH 440 baler Reply to specific post Reply with quote
I've run one since mid 80's. If it has problems, will more than likely be the inside Knotter, I don't know why but that is the one that always gives us the most problems. Switched to plastic twine couple years ago and many issues went away. The few issues that remained where fixed with a needle adjustment, bailed real good after that. Didn't get as much run through it last year due to the rain thou.
I like the knotter being all shaft drive - no chain to mess with for timing. Paul
Texasmark1
PostPosted: Tue May 14, 2019 2:48 pm    Post subject: Re: IH 440 baler Reply to specific post Reply with quote
Mine were 24 and 214 twine.
gotmyfarm!
PostPosted: Tue May 14, 2019 5:01 pm    Post subject: Re: IH 440 baler Reply to specific post Reply with quote
Thanks all. Good info. Now I'm concerned with the bale size this one produces. Are you saying they are huge bales? I don't want really big bales. Can you adjust bale size on any baler? How about tightness of packing? I've bought some tight heavy bales and also have had some fall apart loose fluffy bales. I never thought that a square baler could be a wire tied one because I've never seen wire on a bale. Are there a lot of balers out there that use only wire? Most common balers for sale around here are JD 14 and 24T, and various New Holland models.
RedRoundhead
PostPosted: Tue May 14, 2019 6:38 pm    Post subject: Re: IH 440 baler Reply to specific post Reply with quote
I have a 430.
Good machines, better if they have the All-twine knotters.
Pretty basic machine.
If you get it - get an operators manual for it.
Leroy
PostPosted: Tue May 14, 2019 7:59 pm    Post subject: Re: IH 440 baler Reply to specific post Reply with quote
All square balers can be adjusted for bale length. What you cannot adjust is size of bale chamber and some balers are 14x16" while some are 16x18" and some larger and one model of New Holland had I think a 12"x?' chamber. So a bigger bale chamber on short length pack as many pounds in as a smaller bale chamber in a longer length. I myself would not want a bale chamber of over the 14" x 16" size as even set short 30" they were too heavy for me to handle 40 years ago. Now if you are a body builder weight lifter type of person then the big bale chamber would be OK.
SVcummins
PostPosted: Tue May 14, 2019 8:08 pm    Post subject: Re: IH 440 baler Reply to specific post Reply with quote
I can make bales as light as 50 pounds and as
heavy as 75 with my 440 could probably go lighter if
I shortened them up a hair
Goto page 1, 2  Next
Page 1 of 2
