Briggs with leaky head gasket?
GEO-TH, In
PostPosted: Wed May 15, 2019 12:24 pm    Post subject: Briggs with leaky head gasket? Reply to specific post Reply with quote
Friend was given a 54 inch craftsman mower. Voltage regulator was fired. Replaced it and got it running. Left head gasket was leaking. So friend replace gasket and coated it with #2 permatex. New gasket is leaking.
So is using permatex on head gasket a bad idea? I've never used anything on head gaskets.
Friend has no manual and doesn't know torque sequence either.
Best we could find head bolt torque is about 20#ft.
Any advice?
kencombs
PostPosted: Wed May 15, 2019 1:37 pm    Post subject: Re: Briggs with leaky head gasket? Reply to specific post Reply with quote
First question: is the head surface flat? Sealer shouldn't be needed, but shouldn't cause a leak either.
jeffcat
PostPosted: Wed May 15, 2019 1:55 pm    Post subject: Re: Briggs with leaky head gasket? Reply to specific post Reply with quote
Go on the net and type in Check chart Briggs and Stratton. Gives you all of the answers.
GEO-TH, In
PostPosted: Wed May 15, 2019 2:53 pm    Post subject: Re: Briggs with leaky head gasket? Reply to specific post Reply with quote
No model 44P777. No torque sequence either.
I'm guessing models 445000 my be close, not sure.
kencombs
PostPosted: Wed May 15, 2019 3:48 pm    Post subject: Re: Briggs with leaky head gasket? Reply to specific post Reply with quote
Geo, I found that model number in the first page of the Google response.
Donald Lehman
PostPosted: Wed May 15, 2019 4:03 pm    Post subject: Re: Briggs with leaky head gasket? Reply to specific post Reply with quote
Shouldn't need sealer if the head isn't warped. Take a piece of double thickness glass. Tape a piece of emery cloth on the glass. Lay it on a flat surface and slide the head over it in a circular motion for 15 or 20 strokes. More than likely you will find that it isn't flat.
roy prins
PostPosted: Wed May 15, 2019 4:04 pm    Post subject: Re: Briggs with leaky head gasket? Reply to specific post Reply with quote
Yep -- warped head -- btdt -- Roy
GEO-TH, In
PostPosted: Wed May 15, 2019 4:10 pm    Post subject: Re: Briggs with leaky head gasket? Reply to specific post Reply with quote
He didn't check for flatness. Like others said, good chance head is warped.
T.R.K.
PostPosted: Wed May 15, 2019 5:41 pm    Post subject: Re: Briggs with leaky head gasket? Reply to specific post Reply with quote
I would try again without Permatex. They seal just fine without any help. And I would OIL the threads and torque the bolts to specification.
Also, to prevent that happening in the future, don't close the throttle before you switch it off. Any kind of backfire is bad for head gaskets.
Post new topic    Yesterday's Tractors Forum Index -> Tractor Talk All times are GMT - 8 Hours
