Hydraulic exhaust control valve
Goto page 1, 2  Next
djastram
PostPosted: Mon Jun 10, 2019 6:08 pm    Post subject: Hydraulic exhaust control valve Reply to specific post Reply with quote
I've searched the world over.. And I can't find a place that sells a hydraulic exhaust control valve.
My '49 8N was working fine last year, and then my lift arms wouldn't drop.
After taking the pump out, I found the exhaust control valve spring had came out of the valve cylinder. It seems that what ever keeps the spring inside, is rotted out and gone.
Is there a replacement out there anywhere that will take my money?
Thank you.
David Jastram
Dell Rapids, SD
R Geiger
PostPosted: Mon Jun 10, 2019 6:53 pm    Post subject: Re: Hydraulic exhaust control valve Reply to specific post Reply with quote
Have you checked with CNH dealer? they seem to show that part number.
djastram
PostPosted: Tue Jun 11, 2019 4:07 am    Post subject: Re: Hydraulic exhaust control valve Reply to specific post Reply with quote
R Geiger wrote:
(quoted from post at 19:53:24 06/10/19) Have you checked with CNH dealer? they seem to show that part number.
No, but I will.
Thank you!
JMOR
PostPosted: Tue Jun 11, 2019 6:03 am    Post subject: Re: Hydraulic exhaust control valve Reply to specific post Reply with quote
djastram wrote:
(quoted from post at 22:08:57 06/10/19) I've searched the world over.. And I can't find a place that sells a hydraulic exhaust control valve.
Thank you.
David Jastram
Dell Rapids, SD
The item that keeps spring in there is a very simple flat strap, about 1/8" wide and a length that is equal to the diameter where spring resides and approximately 1/16" thick. Somewhat difficult to press spring down in there and insert strap at angle, then straighten up as spring is released against it. Spring force will keep it in place.
JMOR
PostPosted: Tue Jun 11, 2019 6:52 am    Post subject: Re: Hydraulic exhaust control valve Reply to specific post Reply with quote
picture to add to my post above:
djastram
PostPosted: Tue Jun 11, 2019 2:35 pm    Post subject: Re: Hydraulic exhaust control valve Reply to specific post Reply with quote
Wow. Thanks for the picture. Now I know what it should look like.
My valve end appears to be rotted out, and the strap is no where to be found.
I found a guy at a NH dealer with new/old stock, and he has 4 different sizes.
Can I just use a caliper and measure the diameter, to get close?
Thanks to all.
Dave.
JMOR
PostPosted: Tue Jun 11, 2019 2:39 pm    Post subject: Re: Hydraulic exhaust control valve Reply to specific post Reply with quote
djastram wrote:
(quoted from post at 18:35:23 06/11/19)
Thanks to all.
Dave.
As I recall, they were fitted to less than 0.001 inch, or tenths of a thousandths of an inch. You can likely only get close.
djastram
PostPosted: Tue Jun 11, 2019 4:28 pm    Post subject: Re: Hydraulic exhaust control valve Reply to specific post Reply with quote
https://drive.google.com/open?id=1XBr9mHdFAMsRDTFf8RUZCGxs666ceChP
Not as bad as I thought.
JMOR
PostPosted: Wed Jun 12, 2019 12:38 am    Post subject: Re: Hydraulic exhaust control valve Reply to specific post Reply with quote
djastram wrote:
(quoted from post at 20:28:50 06/11/19)
I bet you can fix it!
djastram
PostPosted: Wed Jun 12, 2019 3:04 pm    Post subject: Re: Hydraulic exhaust control valve Reply to specific post Reply with quote
Look what I found in the bottom of my soaking bucket.
[img][/img]
JMOR
PostPosted: Wed Jun 12, 2019 3:07 pm    Post subject: Re: Hydraulic exhaust control valve Reply to specific post Reply with quote
OK. What is it?
djastram
PostPosted: Wed Jun 12, 2019 3:12 pm    Post subject: Re: Hydraulic exhaust control valve Reply to specific post Reply with quote
The strap that holds the spring in the exhaust control valve.
Now I have something to measure to make the new one.
djastram
PostPosted: Fri Jun 14, 2019 5:52 pm    Post subject: Re: Hydraulic exhaust control valve Reply to specific post Reply with quote
Good as new!
carlntexas
PostPosted: Fri Jun 14, 2019 6:42 pm    Post subject: Re: Hydraulic exhaust control valve Reply to specific post Reply with quote
Good job .
JMOR
PostPosted: Fri Jun 14, 2019 7:38 pm    Post subject: Re: Hydraulic exhaust control valve Reply to specific post Reply with quote
djastram wrote:
(quoted from post at 21:52:00 06/14/19)
Good as new!
good for you!
Goto page 1, 2  Next
Page 1 of 2
