IH 3121 Backhoe Controls not working
irvman358
PostPosted: Wed Jul 10, 2019 10:54 am    Post subject: IH 3121 Backhoe Controls not working Reply to specific post Reply with quote
I have a IH2504 with a 3121 Backhoe, when I first got the machine the backhoe worked but was weak, now none of the controls work at all. By chance I discovered that when I pulled or pushed the swing lever the swing would not work but everything else would. So it seems that the swing lever is either blocking pressure from getting to all of the other functions when it is in the neutral position and/or the pressure is allow to bypass when the swing lever is actuated. Any help would be appreciated. Thanks
greg gg
PostPosted: Wed Jul 10, 2019 4:43 pm    Post subject: Re: IH 3121 Backhoe Controls not working Reply to specific post Reply with quote
On my international 3444 with a 3141 hoe, there is a push/pull valve on the right fender to select either power steering or swing cylinder. When I forget
to pull it up the lift and boom cylinders will still move only if the swing valve is pulled. I would guess you may have similar valve.
irvman358
PostPosted: Wed Jul 10, 2019 5:13 pm    Post subject: Re: IH 3121 Backhoe Controls not working Reply to specific post Reply with quote
That two way valve is on the left side mount almost directly under the seat, I replaced the valve thinking maybe that was the problem but nothing changed.
greg gg
PostPosted: Thu Jul 11, 2019 2:27 am    Post subject: Re: IH 3121 Backhoe Controls not working Reply to specific post Reply with quote
Check the pressure relief valves. I once had a piece of paper towel or shop rag stuck in the valve holding it open.
irvman358
PostPosted: Thu Jul 11, 2019 4:58 am    Post subject: Re: IH 3121 Backhoe Controls not working Reply to specific post Reply with quote
I guess I have to ask how the heck would something like that get into the system but I guess in peoples haste to get things back together anything is possible. I really have no idea where the relief valve is, all of the literature I have bought hasn't helped. I am reluctant to take anything apart without having a clue about how it works and what I might be looking for.
JDEM
PostPosted: Thu Jul 11, 2019 10:52 am    Post subject: Re: IH 3121 Backhoe Controls not working Reply to specific post Reply with quote
The swing circuit uses a totally different hydraulic pump then the rest of the backhoe. I suspect you just have a worn out main hydraulic
pump and maybe the swing pump is bad too.
I battled my 3121 for years as it got weaker and weaker. And just like your's - hitting the swing lever seemed to affect the boom or dipper-
stick speed. It seems to make no sense but it happens just the same. I finally put two new pumps on my 3121 and it has worked great ever
since. That was 5 years ago. Best thing I ever did to the machine.
When I put the two new pumps in I also discovered my machine had no hydraulic filter in it at all. So I flushed it out best I could and put
a new filter in the tank. My 3121 is on a 3414 machine.
irvman358
PostPosted: Thu Jul 11, 2019 1:11 pm    Post subject: Re: IH 3121 Backhoe Controls not working Reply to specific post Reply with quote
CVPost-JDEM wrote:
(quoted from post at 11:52:33 07/11/19) The swing circuit uses a totally different hydraulic pump then the rest of the backhoe. I suspect you just have a worn out main hydraulic
I have changed the pump thinking that it might be the problem, the power steering pump that piggy back on the pump work because the power steering works when I move the two way valve (Which is new) forward when I m not trying to use the backhoe.
JDEM
PostPosted: Thu Jul 11, 2019 2:55 pm    Post subject: Re: IH 3121 Backhoe Controls not working Reply to specific post Reply with quote
Your main pump is likely worn out. You probably have a generic Cessna gear pump. Same as used on many Deere, Ford, Case, etc. backhoes and
tractors.
irvman358
PostPosted: Thu Jul 11, 2019 4:45 pm    Post subject: Re: IH 3121 Backhoe Controls not working Reply to specific post Reply with quote
CVPost-JDEM wrote:
(quoted from post at 15:55:34 07/11/19) Your main pump is likely worn out. You probably have a generic Cessna gear pump. Same as used on many Deere, Ford, Case, etc. backhoes and
tractors.
The pump is literally brand new, if there s 10 hours on it I would be surprise.
JDEM
PostPosted: Thu Jul 11, 2019 5:40 pm    Post subject: Re: IH 3121 Backhoe Controls not working Reply to specific post Reply with quote
Your machine has two new pumps?
irvman358
PostPosted: Fri Jul 12, 2019 1:41 am    Post subject: Re: IH 3121 Backhoe Controls not working Reply to specific post Reply with quote
CVPost-JDEM wrote:
(quoted from post at 18:40:38 07/11/19) Your machine has two new pumps?
Yes the machine has two pumps, one is attached to the other inside the transmission housing, the filter is on the opposite side.
