8n no spark when hot
Goto page Previous  1, 2
J.Mc
PostPosted: Tue Sep 10, 2019 7:34 am    Post subject: Re: 8n no spark when hot Reply to specific post Reply with quote
JMOR or someone can most definitely correct me if I'm wrong, but I don't believe you have enough resistance in your circuit and its overheating your coil. I think you should be at about 4 amps for your coil. A 12v circuit isn't truly 12v. It's more around 14.5. Using ohms law with the information you've provided 14.5 (volts) 2.1 ( your total resistance) = 6.9 (amps). I think you may need another resistor to bring it down some.
Someone please correct me if I'm wrong. I dont claim to be a professional Shocked
JMOR
PostPosted: Tue Sep 10, 2019 7:51 am    Post subject: Re: 8n no spark when hot Reply to specific post Reply with quote
J.Mc wrote:
(quoted from post at 11:34:17 09/10/19) JMOR or someone can most definitely correct me if I'm wrong, but I don't believe you have enough resistance in your circuit and its overheating your coil. I think you should be at about 4 amps for your coil. A 12v circuit isn't truly 12v. It's more around 14.5. Using ohms law with the information you've provided 14.5 (volts) 2.1 ( your total resistance) = 6.9 (amps). I think you may need another resistor to bring it down some.
Correct. The reason I had not already chimed in is that while current needs to be reduced, I have a feeling that it will not fix his problem, unless the coil has been permanently damaged, in which case he needs new coil and reduced current.
Kennyp529
PostPosted: Tue Sep 10, 2019 9:00 am    Post subject: Re: 8n no spark when hot Reply to specific post Reply with quote
I'm going to answer the questions that I know the answers to in bullet format for ease of understanding what I'm trying to say.
1. Coil has 1.4 ohms so I'm assuming that its 6v
2. Old resistor had a ungodly amount of resistance and the tractor wouldn't fire after the rewire so I bypassed it and it fired to life ( so I replaced it.)
3. Wiring is correct. I googled 8n 12v wiring diagram, which brought me to this website and to a comment to us one of JMOR's Pict-o-grams. It was too easy to understand
4. Rewired the tractor because it was a rat's nest of twisted/taped "connections" and someone also used wire nuts instead of butt connectors.
5. Tractor was not running before I started working on it.
6. Before last week, I lived over 1000 miles away from my father. He has 0 mechanic ability so he relied on " the kid down the road" for his tractor "repairs".
I still owe you some answers which I'll post today after I go out to where the tractor is at.
Thanks for the help so far
Kennyp529
PostPosted: Tue Sep 10, 2019 9:34 am    Post subject: Re: 8n no spark when hot Reply to specific post Reply with quote
I forgot to mention that while I was testing the coil resistance yesterday, I noticed a nice big crack down the side of the coil.
Can I replace it with a 12v unit PN : 9N12024-12V.? There is 1 available in town at Rural King.
JMOR
PostPosted: Tue Sep 10, 2019 10:22 am    Post subject: Re: 8n no spark when hot Reply to specific post Reply with quote
Kennyp529 wrote:
(quoted from post at 13:34:43 09/10/19) I forgot to mention that while I was testing the coil resistance yesterday, I noticed a nice big crack down the side of the coil.
yes
Kennyp529
PostPosted: Tue Sep 10, 2019 4:04 pm    Post subject: Re: 8n no spark when hot Reply to specific post Reply with quote
[quote="JMOR"](reply to post at 11:22:22 09/10/19) [/quote
Installed new 12v coil today and mowed for about 45mins. Shut the tractor off and it starts right up now( repeatedly)
Fixing that problem allowed me to uncover another problem..... IT RUNS LIKE $H!T. When it was idling it sounded like a cammed HONDA (terrible). She also lacked power ( pto enabled and disabled)
I found that if I kept my hand on the choke knob and adjusted it, it would run a little less $H!tty.
JMOR
PostPosted: Tue Sep 10, 2019 4:09 pm    Post subject: Re: 8n no spark when hot Reply to specific post Reply with quote
[quote="Kennyp529"](quoted from post at 20:04:35 09/10/19)
Check/clean all three filter screens in fuel path and if all ok, then disassemble carb for a thorough cleaning of every tiny passage.
Tim PloughNman Daley
PostPosted: Wed Sep 11, 2019 12:30 am    Post subject: Re: 8n no spark when hot Reply to specific post Reply with quote
I gotta ask, how does a coil get big rip/tear in it? Your wiring pictogram would be the best source to use for all electrical wiring on N's. "Ungodly amount of resistance". How much is 'ungodly' and how are you checking it? I don't think I've ever checked resistor values, no need. Don't worry about it -resistors are supposed to get hot, have a lot of resistance. Do the coil test as I said. If wiring is correct, distributor tested OK, and a good coil, all should be right with world. Using a new wiring harness is OK as long as it is wired correctly. Buying a new coil: don't rely on what the box, says check it yourself. Having the kid down the road work on it is fine as long as he knows what he is doing.
TPD
Kennyp529
PostPosted: Wed Sep 11, 2019 4:18 pm    Post subject: Re: 8n no spark when hot Reply to specific post Reply with quote
Ok so today i started by draining the fuel from the tank. I disconnected the line at the carb. Inoticed that the fuel flow was poor at times. It would drip, then lightly stream, then flow great, then repeat -- almost in a rhythmic manner. Tank looked great inside ( replaced in the past couple of years. After fuel was drained i washed and blew out the 3 screens. I refilled er and started it up with out any change. A bunch of popping and loping. I was going to try to do a cylinder cut out type test by pulling 1 plug wire at a time but when i reached for the 1st plug boot it shocked the snot out of me. Is this normal.... in not used to working on things with spark plugs.
Kennyp529
PostPosted: Wed Sep 11, 2019 4:22 pm    Post subject: Re: 8n no spark when hot Reply to specific post Reply with quote
Also I belive that the quality TIWAN coil cracked from repeated thermal expansion
HFJ
PostPosted: Wed Sep 11, 2019 5:04 pm    Post subject: Re: 8n no spark when hot Reply to specific post Reply with quote
Kennyp529 wrote:
(quoted from post at 21:18:52 09/11/19) Ok
yes. that spark consists of a whole lot of voltage.
Tall T
PostPosted: Sat Sep 14, 2019 9:30 am    Post subject: Re: 8n no spark when hot Reply to specific post Reply with quote
Kennyp529 wrote:
(quoted from post at 17:18:52 09/11/19) Ok so today i started by draining the fuel from the tank. I disconnected the line at the carb. Inoticed that the fuel flow was poor at times. It would drip, then lightly stream, then flow great, then repeat -- almost in a rhythmic manner. Tank looked great inside ( replaced in the past couple of years. .
Sounds like your tank cap isn't breathing.
Kennyp529
PostPosted: Sat Sep 14, 2019 10:48 am    Post subject: Re: 8n no spark when hot Reply to specific post Reply with quote
Had a similar thought during the draining process. Pulled the gas cap and no change to the flow
Page 2 of 2
