Aftermarket parts
SVcummins
PostPosted: Tue Sep 10, 2019 6:53 pm    Post subject: Aftermarket parts Reply to specific post Reply with quote
Just how long will an aftermarket sway block last ?
Answer not very
r.w.b.
PostPosted: Wed Sep 11, 2019 1:42 am    Post subject: Re: Aftermarket parts Reply to specific post Reply with quote
Dad called em bogus black market junk
M-MAN
PostPosted: Wed Sep 11, 2019 1:47 am    Post subject: Re: Aftermarket parts Reply to specific post Reply with quote
Where's the grease?
Tx Jim
PostPosted: Wed Sep 11, 2019 2:21 am    Post subject: Re: Aftermarket parts Reply to specific post Reply with quote
3 pt draft arms on this tractor must be experiencing some very serious side pull while plowing? to wear sway block that much. Feel free to correct me BUT my understanding of function of sway block is to remove motion of 3 pt draft arms while in transport position not working/plowing position. If plow is adjusted correctly sway blocks should not be needed when plowing.
tim s
PostPosted: Wed Sep 11, 2019 3:39 am    Post subject: Re: Aftermarket parts Reply to specific post Reply with quote
The sad thing is most of the parts coming across the dealer parts counter are the same thing,, Deere is a parts Marketer,,and they simply double or triple the price and slip it into a Deere box..
Glen D Anderson
PostPosted: Wed Sep 11, 2019 4:26 am    Post subject: Re: Aftermarket parts Reply to specific post Reply with quote
Agreed!
When I opened the green & yellow box that contained the bearing for our baler & noticed the letters C-H-I-N-A stamped / etched on the bearing instead of F-A-F-N-I-R, I knew all was lost.......
CVPost-Tim S wrote:
(quoted from post at 04:39:24 09/11/19) The sad thing is most of the parts coming across the dealer parts counter are the same thing,, Deere is a parts Marketer,,and they simply double or triple the price and slip it into a Deere box..
SVcummins
PostPosted: Wed Sep 11, 2019 9:16 am    Post subject: Re: Aftermarket parts Reply to specific post Reply with quote
Almost no side draft . I plow in category one so I
can plow around the corners on headlands.
D-
PostPosted: Wed Sep 11, 2019 9:24 am    Post subject: Re: Aftermarket parts Reply to specific post Reply with quote
I think for plowing the blocks are supposed to be upside down
only to be contacted when plow is raised. That excessive wear
is probably from that oil leak making grinding compound.
Keep it dry as well as drawbar and support.
Tx Jim
PostPosted: Thu Sep 12, 2019 1:54 am    Post subject: Re: Aftermarket parts Reply to specific post Reply with quote
CVPost-SVcummins wrote:
(quoted from post at 13:16:02 09/11/19) Almost no side draft . I plow in category one so I
A better photo would give better idea but sway block in your photo appears to be in Cat ll not Cat l position to my old eyes.
SVcummins
PostPosted: Fri Sep 13, 2019 4:25 pm    Post subject: Re: Aftermarket parts Reply to specific post Reply with quote
It is in 2 now but i am not plowing either .
Tx Jim
PostPosted: Sat Sep 14, 2019 3:14 am    Post subject: Re: Aftermarket parts Reply to specific post Reply with quote
If you're not plowing with sway block in Cat ll position then something besides plow is exerting some "'very serious side draft""
