PTO increaser for Tiller
Kirk-NJ
PostPosted: Wed Dec 11, 2019 2:46 am    Post subject: PTO increaser for Tiller Reply to specific post Reply with quote
I know it's winter and months away from tilling ground. Has anyone tried using a pto gearbox to increase the pto revolutions? Everybody wants the howard for tilling because it
slows the tractor but not the pto. Most people ask if they can run a tiller with a sherman combo, Which many N tractor owners have. The sherman in lower range would slow the
tractor BUT also slow the pto. It seem to me that with the sherman if you could add a gear box that increased the pto speed it might work to run a tiller. It could either be a
chain drive like my ferguson gearbox or gear drive. Any opinions on this subject?
Richard G.
PostPosted: Wed Dec 11, 2019 5:24 am    Post subject: Re: PTO increaser for Tiller Reply to specific post Reply with quote
Sounds like it is worth a try.
A drive box that runs an auger for grain could be used.
They have a chain drive in them with a large and a small sprocket.
I would try to keep the pto speed at near 540 by slowing the engine speed down which would slow the tractor speed down.
You could mount it on the tiller instead of the tractor and just leave it there.
Richard in NW SC
showcrop
PostPosted: Wed Dec 11, 2019 5:40 am    Post subject: Re: PTO increaser for Tiller Reply to specific post Reply with quote
I have a 1974 US built motorcycle that has a speed reducer that is simply a box with two sprockets and a chain. I'll bet that there are many out there in a wide variation of ratios and shaft sizes.
Dean
PostPosted: Wed Dec 11, 2019 5:48 am    Post subject: Re: PTO increaser for Tiller Reply to specific post Reply with quote
In most conditions an 8N with Sherman combination in first/UD will still be too fast for tiller work.
Dean
Kirk-NJ
PostPosted: Wed Dec 11, 2019 5:58 am    Post subject: Re: PTO increaser for Tiller Reply to specific post Reply with quote
That's a good idea to mount it on the tiller
Tomatoboy
PostPosted: Wed Dec 11, 2019 7:16 am    Post subject: Re: PTO increaser for Tiller Reply to specific post Reply with quote
Mounting it on the tiller seems like a pretty decent idea. Actually, now I?m wondering if there are any tillers that would be particularly easy to modify to be driven at a different shaft speed.
TheOldHokie
PostPosted: Wed Dec 11, 2019 8:25 am    Post subject: Re: PTO increaser for Tiller Reply to specific post Reply with quote
CVPost-Kirk-NJ wrote:
(quoted from post at 09:58:21 12/11/19) That's a good idea to mount it on the tiller
Like all of these discusssions a lot depends on soil conditions and the specific design of the tiller. Do the arithmetic:
The Sherman is a 1.513:1 step down so you need a 1.5:1 step up at the PTO to offset the PTO speed hit. With that step up ratio and using first gear step down you are going to attain 540 RPM at the PTO and 1.2 MPH ground speed at 1000 engine RPM.
That is about as slow as you can go with a 540 RPM tiller. My quess is that is a little too fast and depending on the tiller possibly short on torque for virgin soil but probably fine in broken ground. Certainly better than nothing.
TOH
Royse
PostPosted: Thu Dec 12, 2019 8:02 pm    Post subject: Re: PTO increaser for Tiller Reply to specific post Reply with quote
I have not tried it. With or without an adapter.
I have a Sherman combo in my 8N, but a plow and disk combined
are still cheaper than a tiller so I haven't had any desire for a tiller.
