Hydraulic oil
Goto page Previous  1, 2
kyford8n
PostPosted: Fri Dec 13, 2019 7:33 am    Post subject: Re: Hydraulic oil Reply to specific post Reply with quote
Hey guys,
I changed my fluids several months back using UTF. I have a slight leak at my weep hole area and need to add more fluid. Would it hurt anything to add the SAE 90 to the UTF? Just looking to try to slow up the leak a little and wasn't sure if mixing them would hurt anything.
TheOldHokie
PostPosted: Fri Dec 13, 2019 9:43 am    Post subject: Re: Hydraulic oil Reply to specific post Reply with quote
kyford8n wrote:
(quoted from post at 11:33:35 12/13/19) Hey guys,
Mixing won't hurt anything but unless you are adding multiple gallons it won't slow the leak.
TOH
kyford8n
PostPosted: Fri Dec 13, 2019 10:03 am    Post subject: Re: Hydraulic oil Reply to specific post Reply with quote
Thanks TOH,
How bad of a job is it for a rookie to replace the seal?
TheOldHokie
PostPosted: Fri Dec 13, 2019 10:28 am    Post subject: Re: Hydraulic oil Reply to specific post Reply with quote
kyford8n wrote:
(quoted from post at 14:03:48 12/13/19) Thanks TOH,
You have to split and rejoin the tractor behind the engine which will take you a day. Pretty easy in a shop with a floor jack and concrete floor. Not so nice or easy outside and/or on the ground. Other than that nothing difficult about the seal itself. Good time to consider clutch service while you are in there especially given the seal is leaking....
TOH
Page 2 of 2
