JD 3020
keith in mo
PostPosted: Mon Jan 13, 2020 6:10 pm    Post subject: JD 3020 Reply to specific post Reply with quote
having problems with loader not raising with round bale on it, loader is plumbed in through the filter, new filter, cleaned the screen, new oil. so with the loader
plumbed in there does it run off the same hydraulic pump as the scv's? plugged into the scv's with the same result
matthies
PostPosted: Mon Jan 13, 2020 7:24 pm    Post subject: Re: JD 3020 Reply to specific post Reply with quote
Same pump, have you checked pressure? To heavy of a bale?
Tx Jim
PostPosted: Tue Jan 14, 2020 3:21 am    Post subject: Re: JD 3020 Reply to specific post Reply with quote
I agree with matthies that hyd stand-by pressure needs to be checked & set at 2350 psi. Where does frt end loader control valve get it's pressure oil? Does FEL control valve have a closed center plug installed?
tim s
PostPosted: Tue Jan 14, 2020 5:10 am    Post subject: Re: JD 3020 Reply to specific post Reply with quote
Are you getting your supply oil at the filter??..It is meant for return oil there, the supply should be picked up at the fitting in front of the brake peddles..Just checking...
keith in mo
PostPosted: Tue Jan 14, 2020 11:53 am    Post subject: Re: JD 3020 Reply to specific post Reply with quote
Oil returns to the filter housing, supply is teed in , in front of the brake pedal
Tx Jim
PostPosted: Tue Jan 14, 2020 12:37 pm    Post subject: Re: JD 3020 Reply to specific post Reply with quote
It's possible the pressure control valve under hood in frt of firewall is blocking pressure to the line that supplies FEL control valve.
Does power steering operate correctly?
keith in mo
PostPosted: Tue Jan 14, 2020 2:38 pm    Post subject: Re: JD 3020 Reply to specific post Reply with quote
once in a great while it acts like it locks up for a second but other than that it works good
keith in mo
PostPosted: Tue Jan 14, 2020 2:44 pm    Post subject: Re: JD 3020 Reply to specific post Reply with quote
FEL control valve does have a closed center plug. round bales are no heavier than what i always feed. always worked great until recently. seems like the tilt works good so i changed the hoses around on the control valve but that didn't make any difference
Tx Jim
PostPosted: Tue Jan 14, 2020 2:45 pm    Post subject: Re: JD 3020 Reply to specific post Reply with quote
As I stated check pressure control valve under hood
matthies
PostPosted: Tue Jan 14, 2020 5:02 pm    Post subject: Re: JD 3020 Reply to specific post Reply with quote
Maybe you lost a seal in one of the lift cylinders, try and connect a 3000 psi gauge to one of the scv outlets and start there. Use a hose tip, pipe bushing and a gauge.
rrlund
PostPosted: Wed Jan 15, 2020 4:55 am    Post subject: Re: JD 3020 Reply to specific post Reply with quote
That's my thought. I had a loader do that. Somebody on another forum had it happen too. Like me,he was sure the problem was in the tractor and had gone through everything. It was a lift cylinder on the loader letting oil pass by.
Tx Jim
PostPosted: Wed Jan 15, 2020 4:59 am    Post subject: Re: JD 3020 Reply to specific post Reply with quote
Failed piston packing on FEL boom cylinder is definitely a possibility well worth checking.
SVcummins
PostPosted: Thu Jan 16, 2020 2:23 am    Post subject: Re: JD 3020 Reply to specific post Reply with quote
My farmhand loader did the same thing one time and it was bad seals in the hydraulic cylinder
