Disc modification.
Deerfarmer73
PostPosted: Tue Mar 31, 2020 6:43 am    Post subject: Disc modification. Reply to specific post Reply with quote
I appreciate all the feed back guys ,we got this old disc for doing 4-5 acres of food plots ,we were gonna replace the smooth disc's with notched so thought why not try it if the plasma doesn't work we were gonna replace them anyways ,and thought use a template and use the plasma for quick cuts as to not heat up the metal ,I guess it's worth a try .
Leroy
PostPosted: Tue Mar 31, 2020 7:06 am    Post subject: Re: Disc modification. Reply to specific post Reply with quote
Well plan on doing all the work and then replacing the blades as they will be worthless to use after doing all the work. Might as well order the new blades befor starting to notch the old ones.
oliverkid
PostPosted: Tue Mar 31, 2020 8:36 am    Post subject: Re: Disc modification. Reply to specific post Reply with quote
Heat is going to make them brittle. Most likely end up breaking
every one you cut.
MJMJ
PostPosted: Tue Mar 31, 2020 10:04 am    Post subject: Re: Disc modification. Reply to specific post Reply with quote
CVPost-oliverkid wrote:
(quoted from post at 12:36:25 03/31/20) Heat is going to make them brittle. Most likely end up breaking
every one you cut.
Why would they get brittle? If anything it would anneal them, making the cut edges soft and they'll wear more quickly.
Brittleness could happen if they were heated and then quenched, but I doubt that's the plan.
paul
PostPosted: Tue Mar 31, 2020 10:59 am    Post subject: Re: Disc modification. Reply to specific post Reply with quote
I agree with the person below who said leave the blades alone and put more weight on the disk, a couple 100 lbs of wheel weights or the like.
Botched blades aren?t all that, what you want is deeper penetration weight will do that.
Paul
MJMJ
PostPosted: Tue Mar 31, 2020 11:09 am    Post subject: Re: Disc modification. Reply to specific post Reply with quote
Another thing that for me has helped even more than weight, is use the longest top link you can find. The rear of my 3pt disc is barely off the ground when I pick it up, but it only takes me a couple passes to turn sod into dirt ready to plant. I have all smooth blades.
ztrmowers
PostPosted: Wed Apr 01, 2020 6:25 am    Post subject: Re: Disc modification. Reply to specific post Reply with quote
why? are you needing more cut, then just add some weight
big tee
PostPosted: Wed Apr 01, 2020 7:34 am    Post subject: Re: Disc modification. Reply to specific post Reply with quote
I have notched a lot of blades with a plasma cutter. I do it so they won't slide instead of for better cut. By using the plasma instead of a torch you don't get them hot so no problem with heat problems. Did it both on the leveler I built behind the soil saver plus a old BWA disc we pull behind the stalk cutter--re-sharpen as needed---Tee
SVcummins
PostPosted: Sun Apr 05, 2020 3:55 am    Post subject: Re: Disc modification. Reply to specific post Reply with quote
Is that an 8960? Never dreamed notching your own blades would work
big tee
PostPosted: Tue Apr 07, 2020 7:21 am    Post subject: Re: Disc modification. Reply to specific post Reply with quote
Sorry I did not see your post SV--I don't know if the notched blades would hold up on a heavy disc but for what we do it works for us--Like I said it is mostly to keep the gangs from sliding. It is a 8760 had a 7020-ST-250 and a Cougar 1000-then got the 8760--The wife runs it most of the time--She likes it--Stay Safe SV---Tee
