Help for AC 175 Wheel centers Paint Code
TJ in KY
PostPosted: Thu Jun 11, 2020 8:33 am    Post subject: Help for AC 175 Wheel centers Paint Code Reply to specific post Reply with quote
On an Allis Chalmers 175 (year 1977)For the Cream wheel centers the codes I have found are a PPG 8638 and 23056 from Rod NH site.or possibly a Ditzler 921091, My paint supplier says he can find nothing using those numbers. I was looking for PPG Omni numbers (MTK) as I have used that paint in the past with good results (ford Tractor)
Stephen Newell
PostPosted: Thu Jun 11, 2020 7:21 pm    Post subject: Re: Help for AC 175 Wheel centers Paint Code Reply to specific post Reply with quote
If you can't find the code, is there any place where the old paint is viable. If so you can sand it to clean it and clear coat it. The paint shop should be able to computer match the paint from the sample.
showcrop
PostPosted: Fri Jun 12, 2020 3:02 am    Post subject: Re: Help for AC 175 Wheel centers Paint Code Reply to specific post Reply with quote
TJ, Stephen is referring to digital analysis. I have had it done. You have to take them a part that has a 6 inch square flat area. That could be difficult with a wheel.
Stephen Newell
PostPosted: Fri Jun 12, 2020 4:12 am    Post subject: Re: Help for AC 175 Wheel centers Paint Code Reply to specific post Reply with quote
The place I use has a gadget not much more than an inch in diameter they can put on a paint sample.
showcrop
PostPosted: Fri Jun 12, 2020 4:39 am    Post subject: Re: Help for AC 175 Wheel centers Paint Code Reply to specific post Reply with quote
CVPost-Stephen Newell wrote:
(quoted from post at 05:12:39 06/12/20) The place I use has a gadget not much more than an inch in diameter they can put on a paint sample.
Stephen, that is good to know. Maybe my store has one of those now.
TJ in KY
PostPosted: Fri Jun 12, 2020 4:59 am    Post subject: Re: Help for AC 175 Wheel centers Paint Code Reply to specific post Reply with quote
Thanks for the suggestions, unfortunately I have already stripped the wheel centers. the only thing I have left is the front rims (with tires still on them) that I was planning to do at a later date. I will keep looking and if I find something I will post the results.
Stephen Newell
PostPosted: Fri Jun 12, 2020 2:37 pm    Post subject: Re: Help for AC 175 Wheel centers Paint Code Reply to specific post Reply with quote
I looked at pictures of that tractor. Unless it has to be a factory match it wouldn't be difficult to mix that color. You could just take some white paint and add a very small amount of yellow oxide pigment to it. Just a couple drops per quart should do it.
TJ in KY
PostPosted: Mon Jun 29, 2020 12:34 pm    Post subject: Re: Help for AC 175 Wheel centers Paint Code Reply to specific post Reply with quote
Here is finished product..waiting on tire man. Forgot to get pictures after he left. Tractor is in Indiana.
Stephen Newell
PostPosted: Tue Jun 30, 2020 10:47 am    Post subject: Re: Help for AC 175 Wheel centers Paint Code Reply to specific post Reply with quote
Every time I paint a rim the tire guy gouges the paint all to heck mounting the tire. One place even put a UPC sticker on the fresh paint you would think they used epoxy for the adhesive on the sticker. Ended up having to sand the sticker off.
Post new topic    Yesterday's Tractors Forum Index -> Paint and Bodywork All times are GMT - 8 Hours
