2424 - how much Hy-Tran?
Tim in New York
PostPosted: Sun Jun 28, 2020 7:38 am    Post subject: 2424 - how much Hy-Tran? Reply to specific post Reply with quote
Time to change the transmission fluid on my tractor and I am not sure how much it needs. First time I did it I am pretty sure there was much more than 5 gallons in it, but its been a long time. My IT shop manual says 5 gallons, so that is how much I put back in. I since got a reprint of an owners manual that says the same, but has a note:
"5 gallons without front mounted hydraulic pump or draft control"
"14 gallons with front mounted hydraulic pump without draft control"
"17 gallons with front mounted hydraulic pump and draft control"
The pump runs off the side of the engine, just behind the fan. Is that what is meant by "front mount" The tractor originally had something run off the front of the crankshaft, as the grille screen had a round hole cut it in - i assumed that would have been the front mount pump.
And pretty sure it has draft control - it has a small 2nd lever next to the the 3 pt lever. And it looks like the top link has a large spring and some kind of sensor behind it.
How much do I need? Have I really been running it with less than half the required fluid all these years?
Thanks!
Tim
wore out
PostPosted: Sun Jun 28, 2020 7:56 am    Post subject: Re: 2424 - how much Hy-Tran? Reply to specific post Reply with quote
"The pump runs off the side of the engine, just behind the fan. Is that what is meant by "front mount"?"
No, you don't have a "front-mount" pump.
A "front-mount" pump (AKA, a "stinger pump) would be an external pump, mounted ahead of the engine and driven with a short driveshaft from the front of the engine crankshaft.
Tim in New York
PostPosted: Sun Jun 28, 2020 8:26 am    Post subject: Re: 2424 - how much Hy-Tran? Reply to specific post Reply with quote
OK - so that means 5 gallons, even though I have draft control, right?
wore out
PostPosted: Sun Jun 28, 2020 8:37 am    Post subject: Re: 2424 - how much Hy-Tran? Reply to specific post Reply with quote
Sounds like a stupid error or typo in the I&T manual. TYPICAL.
AFAIK, if a "424" was equipped with a 3-point it had draft control.
I have a "424" and need to change the transmission and the hydraulic oil.
I will look at the original Operator's Manual I have tomorrow and see what that has to say on the topic.
warren woodrow
PostPosted: Mon Jun 29, 2020 7:14 pm    Post subject: Re: 2424 - how much Hy-Tran? Reply to specific post Reply with quote
Struggled with that wording for years and did not know how much to put in mine . I agree that front mounted does NOT refer to the pump on the right hand side of engine . Mine has draft control [ and of course 3 point hitch ] I run 5 gallons .
Tim in New York
PostPosted: Tue Jun 30, 2020 12:07 pm    Post subject: Re: 2424 - how much Hy-Tran? Reply to specific post Reply with quote
Thanks Warren - was hoping you would respond. I am gonna go with 5 gallons of Rotella HD hydraulic fluid. It supposedly meets HY-Tran specs and I can get it a TSC with a couple unused gift cards I had.
I think last time I used heavy 80 or 90 weight gear oil.
Tim
warren woodrow
PostPosted: Tue Jun 30, 2020 1:50 pm    Post subject: Re: 2424 - how much Hy-Tran? Reply to specific post Reply with quote
CVPost-Tim in New York wrote:
(quoted from post at 13:07:33 06/30/20) Thanks Warren - was hoping you would respond. I am gonna go with 5 gallons of Rotella HD hydraulic fluid. It supposedly meets HY-Tran specs and I can get it a TSC with a couple unused gift cards I had.
Tim
Hy Tran will be great . I run 303 with no problems . Used to severely overfill it due to confusion and thought i had bad seals it leaked so much !!!!
