MF 750 Combine
pcrh
PostPosted: Sat Aug 01, 2020 4:42 am    Post subject: MF 750 Combine Reply to specific post Reply with quote
Hi:
I am going to look at a Massey Ferguson 750 Combine and then a 850 combine both with grey cab. Looking for tips on what to check. Good/Bad, weak points.
Thanks
rustred
PostPosted: Sat Aug 01, 2020 12:00 pm    Post subject: Re: MF 750 Combine Reply to specific post Reply with quote
the 750 is the prior model and is shorter. basically the same unit. i have the last year biult 850 . just says massey in big letters not
massey ferguson. the main drive belt is one of the weak points. other than that good combine and check the normal wearing items like rub bars
sives, chains, and such. mine is 1987 i think. dont really have any complaints on it. i dont like is for canola though. you need to add
screens on the straw walkers for a clean job. barley wheat is good.
pcrh
PostPosted: Sat Aug 01, 2020 7:14 pm    Post subject: Re: MF 750 Combine Reply to specific post Reply with quote
Hi rustred:
Thanks for your thoughts.
The 750 would then be a smaller capacity machine? And, either machine should handle my 300 acres with no problems.
Thanks
rustred
PostPosted: Sat Aug 01, 2020 7:21 pm    Post subject: Re: MF 750 Combine Reply to specific post Reply with quote
should be no problem if a person has good weather. i had a 750 first and did 3 quarters. it was 1979 silver cab also.
David Lohf
PostPosted: Sun Aug 02, 2020 6:30 am    Post subject: Re: MF 750 Combine Reply to specific post Reply with quote
We had a 750 for a while it was a good combine except for the oil cooler radiator was too close to the engine radiator that it
caused overheating. the solution was tomove the oil cooler to the outside like a 850's. they had a fan that ran off the engine to
keep it cool,it blew all heat out of engine compartment.
pcrh
PostPosted: Mon Aug 03, 2020 5:16 am    Post subject: Re: MF 750 Combine Reply to specific post Reply with quote
Hi David Lohf:
Thanks for your thoughts. Do you farm in a warm area?
David Lohf
PostPosted: Mon Aug 03, 2020 2:15 pm    Post subject: Re: MF 750 Combine Reply to specific post Reply with quote
I live in Iowa with normal weather. The problem was a bad design with engine radiator getting its air from a hot oil cooler inches
away, The 850 would be my bet in a heart beat.
pcrh
PostPosted: Tue Aug 04, 2020 4:50 am    Post subject: Re: MF 750 Combine Reply to specific post Reply with quote
[quote="CVPost-David Lohf"](reply to post at 15:15:58 08/03/20) [/quote]
Hi David Lohf:
Thanks
pcrh
PostPosted: Wed Aug 05, 2020 1:22 pm    Post subject: Re: MF 750 Combine Reply to specific post Reply with quote
Hi:
In talking with neighbours, they say the combines would be to big for me as I only have a 16 foot windrower/swather. Says the combine will not thrash the grain clean. Are they just grumbling or is their merit to their comments.
Thanks
