Another 830 2 cyl ES question (seized)
Goto page 1, 2  Next
MikeGreen830
PostPosted: Tue Oct 13, 2020 10:43 am    Post subject: Another 830 2 cyl ES question (seized) Reply to specific post Reply with quote
I've already asked a couple questions on here and have had great advice, I thank you. This 830 that I have is just sitting and hasn't been started in several years. I am trying to assess things and was wondering, can I tell if the engine is seized by removing the flywheel cover and try to turn the flywheel by hand? I know nothing and need some advice here, thanks.
Dan in Ohio
PostPosted: Tue Oct 13, 2020 11:14 am    Post subject: Re: Another 830 2 cyl ES question (seized) Reply to specific post Reply with quote
Mike,
I am just guessing here as I have not tried this but it seems to me that if you pull the compression release lever that should
allow you to turn the fly wheel with the aid of a bar at least enough to confirm that is stuck or free. Would be easy enough
to try.
buickanddeere
PostPosted: Tue Oct 13, 2020 11:41 am    Post subject: Re: Another 830 2 cyl ES question (seized) Reply to specific post Reply with quote
Take the rocker cover off and ensure the valves are free to move .
MikeGreen830
PostPosted: Tue Oct 13, 2020 11:50 am    Post subject: Re: Another 830 2 cyl ES question (seized) Reply to specific post Reply with quote
Thanks Dan, appreciate it!
MikeGreen830
Thanks buickanddeere, will do!
WeirdDeere
PostPosted: Tue Oct 13, 2020 2:31 pm    Post subject: Re: Another 830 2 cyl ES question (seized) Reply to specific post Reply with quote
You can turn the flywheel by hand, at least back and forth, if you're up against compression might not want to roll over easy, if you pull the compression release it should roll just fine.
Brandon
MikeGreen830
PostPosted: Tue Oct 13, 2020 3:26 pm    Post subject: Re: Another 830 2 cyl ES question (seized) Reply to specific post Reply with quote
Thanks, Brandon.
MikeGreen830
PostPosted: Sat Oct 17, 2020 2:46 pm    Post subject: Re: Another 830 2 cyl ES question (seized) Reply to specific post Reply with quote
Ok, I took the flywheel cover off and with the decompression lever held back, I could turn the flywheel about a 1/4 turn or more each way. When I turned it towards the front of the tractor when I got where I couldn't turn any further it acted like it wanted to pull the tractor forward. Is this a good sign or should I be able to turn the flywheel all the way around?
MikeGreen830
PostPosted: Sat Oct 17, 2020 2:49 pm    Post subject: Re: Another 830 2 cyl ES question (seized) Reply to specific post Reply with quote
I should have mentioned I turned it by hand.
J.Wondergem
PostPosted: Sat Oct 17, 2020 4:13 pm    Post subject: Re: Another 830 2 cyl ES question (seized) Reply to specific post Reply with quote
It isn't stuck in gear, is it?
coonie minnie
PostPosted: Sat Oct 17, 2020 4:20 pm    Post subject: Re: Another 830 2 cyl ES question (seized) Reply to specific post Reply with quote
Shift the tractor to neutral... if it is moving the tractor, the tractor is likely in gear and the clutch sticking a bit...
MikeGreen830
PostPosted: Sat Oct 17, 2020 4:56 pm    Post subject: Re: Another 830 2 cyl ES question (seized) Reply to specific post Reply with quote
Oops I didn't take the tractor out of gear, that makes sense now. I'll try again tomorrow. Should I be able to turn the flywheel all the way around by hand in neutral then?
MikeGreen830
PostPosted: Sun Oct 18, 2020 7:19 am    Post subject: Re: Another 830 2 cyl ES question (seized) Reply to specific post Reply with quote
Tried it again this morning with the tractor out of gear and still only able to turn it one way or the other about a quarter turn or more. Not sure if this is a good sign or should the flywheel turn all the way around by hand?
MikeGreen830
PostPosted: Mon Oct 19, 2020 4:39 am    Post subject: Re: Another 830 2 cyl ES question (seized) Reply to specific post Reply with quote
Ok, so when I turn the flywheel towards the front of the tractor, it acts like it is hitting something and when I turn it towards the rear as far as I can, I hear a slight squeak, like maybe metal on metal and it gets stuck. I put muscle to it and can get it unstuck. If it was freed up, I should be able to turn it 360 by hand, correct? Decompression lever is back and tractor out of gear. Haven't checked on the valves yet.
Kendall W
PostPosted: Tue Oct 20, 2020 6:43 am    Post subject: Re: Another 830 2 cyl ES question (seized) Reply to specific post Reply with quote
MikeGreen830 wrote:
(quoted from post at 05:39:28 10/19/20) Ok, so when I turn the flywheel towards the front of the tractor, it acts like it is hitting something and when I turn it towards the rear as far as I can, I hear a slight squeak, like maybe metal on metal and it gets stuck. I put muscle to it and can get it unstuck. If it was freed up, I should be able to turn it 360 by hand, correct? Decompression lever is back and tractor out of gear. Haven't checked on the valves yet.
Back in 2012 I bought a kind of stuck 820 green dash. I poured a couple of litres of diesel down the muffler and walked away for a week. I could only move it 8 teeth on the ring gear before it got tight. Then went back the other way. Took a lot of back and forth but eventually went all the way around 4 times. It would not start with the pup motor so we pull started it and it took off right quick. It had kind of strange pop to hear it run but it ran. Probalby a sticking valve. I new it just needed to be worked for a while. Everyone was trying to tell me it needed fuel pump work. I knew it just needed to work. A couple years later I had the chance to pull a blade for 3 hours with it. That cleaned it right up and now she sounds good. Makes 58 horse on the dyno like it should. The good part of pulling an implement is that the govenor gets worked also as a dyno deosen,t do that. Your 830 should make 69 HP on the dyno like mine does if nobody screwed with the fuel. Just don,t force anything and be gentle with it. Good luck.
Goto page 1, 2  Next
Page 1 of 2
