Intake and exhaust manifold
Brad500
PostPosted: Fri Oct 16, 2020 6:16 am    Post subject: Intake and exhaust manifold Reply to specific post Reply with quote
I was beginning to take off the carburetor last night but noticed where the carburetor attaches to the intake there appears to be a separation between the intake pipe and where the carburetor attaches. It doesn't look like it is cracked but very clean as if someone sawed through it. Is it supposed to be this way? I would think this would allow air to get it from the outside and the carburetor to set to run to rich. I have looked an the manifolds offered as replacements and they appear to made differently. Will a replacement manifold fit with no modifications needed? Thanks in advance.
J.Wondergem
PostPosted: Fri Oct 16, 2020 6:27 am    Post subject: Re: Intake and exhaust manifold Reply to specific post Reply with quote
I can't see it, but it doesn't sound right. Can you get a light to shine on it better when taking the picture?
Brad500
PostPosted: Fri Oct 16, 2020 6:57 am    Post subject: Re: Intake and exhaust manifold Reply to specific post Reply with quote
It is right below the plug on the intake. I will try to take a better photo tonight.
Jim in rush co
PostPosted: Fri Oct 16, 2020 1:45 pm    Post subject: Re: Intake and exhaust manifold Reply to specific post Reply with quote
I had my TO35 running today and thought of your manifold post so I grabbed a couple of pictures. Are these what you are talking about? Made that way to take the high heat of the exhaust and the cool of the intake at the same time.
Brad500
PostPosted: Fri Oct 16, 2020 1:54 pm    Post subject: Re: Intake and exhaust manifold Reply to specific post Reply with quote
CVPost-Jim in Rush co wrote:
(quoted from post at 14:45:31 10/16/20) I had my TO35 running today and thought of your manifold post so I grabbed a couple of pictures. Are these what you are talking about? Made that way to take the high heat of the exhaust and the cool of the intake at the same time.
<img src="/cvphotos/cvphoto59616.jpg">
<img src="/cvphotos/cvphoto59617.jpg">
No right below the vacuum plug. The carburetor is below that and attached to the the intake part of the manifold. Just above the flange where the carburetor is attached is the separation You can see it in the photo.
J.Wondergem
PostPosted: Sat Oct 17, 2020 1:17 pm    Post subject: Re: Intake and exhaust manifold Reply to specific post Reply with quote
I think I see maybe where your talking about. Kind of looks like a flange or something in the casting a inch or two below the vacuum plug?
J.Wondergem
PostPosted: Sat Oct 17, 2020 1:27 pm    Post subject: Re: Intake and exhaust manifold Reply to specific post Reply with quote
Another thought, you could spray some WD40 or something on it while it's idling and see if it speeds up.
Brad500
PostPosted: Sat Oct 17, 2020 4:49 pm    Post subject: Re: Intake and exhaust manifold Reply to specific post Reply with quote
Yes that’s it took off the carb and it appears it just
one solid piece maybe left over from manufacturers.
Just appears to be two pieced
J.Wondergem
PostPosted: Sun Oct 18, 2020 9:13 am    Post subject: Re: Intake and exhaust manifold Reply to specific post Reply with quote
Glad to hear that.
