funnel
Ellis Kinney
PostPosted: Sat Nov 21, 2020 7:07 am    Post subject: funnel Reply to specific post Reply with quote
Has anyone on this website invented a good funnel for putting oil in a Farmall M or H? Changed oil in three M's yesterday with the funnel tied to keep it from falling out. Ellis
DeltaSteve
PostPosted: Sat Nov 21, 2020 7:13 am    Post subject: Re: funnel Reply to specific post Reply with quote
I too have found a funnel on those is an exercise in futility.I just carefully use a one gallon oil jug and pour it in.If I'm careful and take my time and not try to hurry,I dont spill a drop.
rustred
PostPosted: Sat Nov 21, 2020 7:44 am    Post subject: Re: funnel Reply to specific post Reply with quote
i pour into a 1 gallon jug first and it works ok. also have a one gallon plastic shell container with the built in spout i also use.
David G
PostPosted: Sat Nov 21, 2020 8:59 am    Post subject: Re: funnel Reply to specific post Reply with quote
They are PIA, I just use a small container and pour real slow.
Ellis Kinney
PostPosted: Sat Nov 21, 2020 11:57 am    Post subject: Re: funnel Reply to specific post Reply with quote
I always start out with a gallon container and when I can't pour any more with that I pour the rest into a quart can. I'm going to invent something!!! Keep your eyes open, I'll be selling the patent. Ellis
DR. EVIL
PostPosted: Sat Nov 21, 2020 1:38 pm    Post subject: Re: funnel Reply to specific post Reply with quote
I still have one of those good oil can piercing pouring spouts, has the rubber seal to contain the oil in the spout where it enters the can.
Now, where do I find round steel top&bottom quart cans? Years ago Dad used to buy cases of quart cans, cases of 4 quart cans and cases of 5 quart cans, He used two 4 quart cans in the M's & SM's, a 5 quart can and a quart in H's.
I have to change the oil & filter in the Super H before it snows. I'll release the right side hood latches, prop the hood up a bit, and even with the loader on I can pour oil from the gallon Rotella jugs in the oil fill without spilling a drop.
glennster
PostPosted: Sat Nov 21, 2020 3:13 pm    Post subject: Re: funnel Reply to specific post Reply with quote
i use the galvanized oil fillers with spout. i have a one and two quart , the work good on the m and h. here is a link to what they look like
poke here
MARK ROBKE
PostPosted: Sat Nov 21, 2020 3:58 pm    Post subject: Re: funnel Reply to specific post Reply with quote
My Dad always used a 2qt container that had a flexible metal pour tube. We had a 300u and 340u that it was perfect for. He just laid a rag over the top of the container when it sat on the shelf. Mark.
larbear
PostPosted: Sat Nov 21, 2020 4:07 pm    Post subject: Re: funnel Reply to specific post Reply with quote
Take a litre or quart container and cut it in half and use the top half as a funnel.
View user's profile AIM Address
Kansas4010
PostPosted: Sat Nov 21, 2020 4:17 pm    Post subject: Re: funnel Reply to specific post Reply with quote
I have a couple cases of them sitting in the barn that belonged to my dad. If I remember they are Skelly brand. Still full of oil.
fastfarmall
PostPosted: Sat Nov 21, 2020 8:59 pm    Post subject: Re: funnel Reply to specific post Reply with quote
I put the funnel over top the bolt, the cover stud bolt, and that hold the the funnel in place, and seldom spill unless i pour to fast!!
SadFarmall
PostPosted: Sat Nov 21, 2020 9:22 pm    Post subject: Re: funnel Reply to specific post Reply with quote
I use a one quart bottle with its own funnel. Works very well for Farmall M and Farmall H. Farmall M with AH-84 Angle and Tilting Blade makes it an awful job without a pump out of a drum.
SadFarmall
First photograph shows bottle - One Imperial Quart
Second photograph of my Farmall M, showing frame in front of oil filler.
pete 23
PostPosted: Sun Nov 22, 2020 6:47 am    Post subject: Re: funnel Reply to specific post Reply with quote
Piece of card board.
caterpillar guy
PostPosted: Sun Nov 22, 2020 11:32 am    Post subject: Re: funnel Reply to specific post Reply with quote
On thwe poke here link if you go to the bottom right I like the black one with the thumb lever to let oil out and stop flow with. Can get the spout where you want it then let the flow go.
kevinj54
PostPosted: Sun Nov 22, 2020 11:34 am    Post subject: Re: funnel Reply to specific post Reply with quote
CVPost-caterpillar guy wrote:
(quoted from post at 15:32:14 11/22/20) On thwe poke here link if you go to the bottom right I like the black one with the thumb lever to let oil out and stop flow with. Can get the spout where you want it then let the flow go.
I use those or oil bottle like Sad shows.
