8N starting issues
Goto page Previous  1, 2
Den N Ms
PostPosted: Sat Nov 21, 2020 2:04 pm    Post subject: Re: 8N starting issues Reply to specific post Reply with quote
PhilWV, If you have good spark now,with a spark tester or a 1/4" gapped old plug.Try this to get your engine running.Get a new set of plugs as yours could be fouled/flooded from fuel deposits from trying to start iy manny times.I recommend (NGK 3112 (B-4l) plugs.Squirt 2-3 pumps of engine oil in a oil can. or 1 teaspoon of oil down each plug hole before installing new plugs.This will increase compression and help it start.A squirt of starting fluid into carb intake when cranking over with ignition on and throttle 1/4 to 1/2 way open.No choke needed with starter fluid.Try this!
PhilWV
PostPosted: Mon Nov 23, 2020 2:57 pm    Post subject: Re: 8N starting issues Reply to specific post Reply with quote
Thanks everyone for the advice. For the update, I'm still not getting a spark. I got the adjustable spark tester, same result as the opened-up plug: nothing. A couple of times I got a very weak and inconsistent spark with the tester opened <1/16", but that's it.
I went back out with the multimeter and I'm getting the right voltage at the coil: same as battery when the points are open, half that when closed.
Bruce, I went through your 10 most common distributor-related reasons for a weak spark and your continuity tests for inside the distributor - again - in case I missed something the first time. This time around I dressed the points with cardstock like you suggested, even though the points look pristine and I'm not getting any resistance reading between them. There was a little carbon streaking on the bronze contact points inside the cap but not much, it came off with steel wool. Did a continuity test before I put the distributor back on, and it was fine: no continuity between the top of the coil and the distributor body when points are open, slight resistance from the coil when they're closed.
I don't get it. Brand new battery, continuity in all the right places, but no spark. Could the coil be bad?
PhilWV
PostPosted: Tue Nov 24, 2020 2:54 pm    Post subject: Re: 8N starting issues Reply to specific post Reply with quote
Don't laugh... I was rushing a bit yesterday and didn't connect the top terminal of the coil when I tested for spark. Spotted it first thing today and hooked it up, sparking great now. :roll: (OK, you can laugh.)
Problem is I still can't get it to run, even after swapping out the old plugs for new AL 437s. I crank it a few times with the ignition off, then turn the ignition on and pull out the choke for a split second -- it starts -- sputters for 3 or 4 seconds at most, and then gives out. After about 3 tries, the engine's flooded. Then if I pull the spark plugs and wipe them dry, it'll fire again.
HFJ
PostPosted: Tue Nov 24, 2020 5:15 pm    Post subject: Re: 8N starting issues Reply to specific post Reply with quote
PhilWV wrote:
(quoted from post at 18:54:55 11/24/20)
try less choke. the flooding is <almost> certainly the result of too much choke.
Page 2 of 2
