rust-ospho
MI-Bill
PostPosted: Sun Nov 22, 2020 7:19 am    Post subject: rust-ospho Reply to specific post Reply with quote
I have some parts that someone grinded and sanded many years ago. they are now coated in a pretty good film of rust . debating treating with a rust remover before sanding as opposed to sanding first and then treating. Comments? quite a few parts.
showcrop
PostPosted: Sun Nov 22, 2020 9:34 am    Post subject: Re: rust-ospho Reply to specific post Reply with quote
It depends on what "a pretty good film" is. The rust converters work very well but they don't penetrate much. If you can scrape much off with something like the edge of a screwdriver you probably should sand or wire wheel first. On sheet metal use a twisted cup type wire wheel, and on the cast iron and heavy steel parts a #80 flap wheel.
Mike(NEOhio)
PostPosted: Sun Nov 22, 2020 1:35 pm    Post subject: Re: rust-ospho Reply to specific post Reply with quote
Evapo-Rust. Wire brush as best you can, soak and rinse.
Bruce(OR)
PostPosted: Mon Nov 23, 2020 8:07 pm    Post subject: Re: rust-ospho Reply to specific post Reply with quote
Muriatic acid, Ospho, Electrolysis, Naval Jelly, Vinegar, Pick one, pick all. I suspect it depends on what size and recesses. Treat with what? Paint?
showcrop
PostPosted: Tue Nov 24, 2020 4:58 am    Post subject: Re: rust-ospho Reply to specific post Reply with quote
CVPost-Bruce(OR) wrote:
(quoted from post at 21:07:08 11/23/20) Muriatic acid, Ospho, Electrolysis, Naval Jelly, Vinegar, Pick one, pick all. I suspect it depends on what size and recesses. Treat with what? Paint?
Bruce, some simply remove rust while othere convert it to iron phosphate. Iron phosphate is what your air impact wrench sockets are plated with.
FBH44
PostPosted: Thu Nov 26, 2020 11:08 am    Post subject: Re: rust-ospho Reply to specific post Reply with quote
Thing I like about vinegar is if you let things sit for a few days, the rust just falls off, leaves a black oxide as I recall.
Post new topic    Yesterday's Tractors Forum Index -> Paint and Bodywork All times are GMT - 8 Hours
