Author |
Message |
Case Nutty 1660 Tractor Guru
Posted: Sun Nov 29, 2020 5:04 am Post subject: IH shredder |
I need to write down the model of this mower/shredder I have I can still see the model if the light is just right I think,, anyway wondering how many have seen or used this model, the twin blades with a stationary mounted one that runs between the two sets of swinging blades really does a heck of a job,, I normally run it with a 20-30 hp unit but I like the cab a whole lot better this time of year, plus it keeps you out of the dust and flying debris,, I was chopping up the regrowth tumble weed row along the strips here, as you can see it leaves nothing of them even walking 8 mph, just thought i would share this is the only one I have ever seen out here
cnt
Back to top |
Loosehandle Long Time User
Posted: Sun Nov 29, 2020 5:59 am Post subject: Re: IH shredder |
Careful you don't walk through the gearbox.... |
Back to top |
Absent Minded Farmer Tractor Guru
Joined: 03 Sep 2007 Posts: 4064 Location: Gehl Country, Wi.
Posted: Sun Nov 29, 2020 6:25 am Post subject: Re: IH shredder |
It's a 25. I've seen them. Haven't used one. Tough unit, but not as rugged as the x10 or x11 series. Don't know if you will be taking down trees with it.
See video below.
Mike
Clear pastures ahead....
Back to top |
J Hamilton Tractor Expert
Posted: Sun Nov 29, 2020 6:33 am Post subject: Re: IH shredder |
Holy cow! And that's why so many old rotary cutters are beat to death, gearboxes destroyed and decks bent, warped, and a ring around the top where the blades have gotten them. Nice promotional video though. |
Back to top |
TractorTucker Long Time User
Posted: Sun Nov 29, 2020 7:05 am Post subject: Re: IH shredder |
I'm amazed the grill on that tractor got off without a dent.
The mowing down a tree part did not work out so well for the last mower I saw that tried it. Maybe if it was an IH instead of a Woods.
Back to top |
Posted: Sun Nov 29, 2020 7:42 am Post subject: Re: IH shredder |
Mine looks to be a older built unit as mine has a different drive shaft and gear box,, that model # sounds close though if not right on the money,, the one in the vid only has one set of blades also where mine has two, I would not use it for that kind of cutting as I have no tree growth like that to control,, Neat vid thanks for sharing it |
Back to top |
Posted: Sun Nov 29, 2020 8:17 am Post subject: Re: IH shredder |
it has a shear bolt in the drive system so there is no more hp put through the gear box than the shear bolt allows,, and then I am not trying to cut trees with it like in the vid lol |
Back to top |
shaun wallace Tractor Guru
Posted: Sun Nov 29, 2020 10:44 am Post subject: Re: IH shredder |
There are a few still out here in West Central TX. Used to chop cotton stalks. Have seen with 2 arches for plant to go thru. |
Back to top |
casecollectorsc Tractor Guru
Posted: Sun Nov 29, 2020 10:54 am Post subject: Re: IH shredder |
Hutterites came along last summer with a shredder cleaning up the field edge. Across from my drive way is a larger tree. Operator decided to back up to the tree and cut the tall grass...nobody told him there was a rock pile there. Gearbox exploded and parts laying around after he limped home. |
Back to top |
psimmer Regular
Posted: Mon Nov 30, 2020 6:08 am Post subject: Re: IH shredder |
I have a model 5 foot model 311 pull type that looks quite similar. Works real well and is in quite nice shape. |
Back to top |
super99 Tractor Guru
Joined: 19 Jan 2002 Posts: 5021 Location: Rock Island county, Ill
Posted: Mon Nov 30, 2020 5:02 pm Post subject: Re: IH shredder |
I have a similar IH cutter that I haven’t used in years. My blades are fixed, not free on the end. It has shear bolts. I have cut a lot of trees off with it. If the tractor will push em down, it’ll cut em off. I’ve even backed it up on bigger trees and let it down to cut them off. Maybe I oughta clean it up and try to sell it.
Back to top |
Posted: Tue Dec 01, 2020 9:28 pm Post subject: Re: IH shredder |
Didn't notice it before, but the axle clamps, axle & gear box are the same as what is on my hay conditioner. Interesting. Didn't think that box would take that much of a beating.
Mike |
Back to top |
onefarmer Tractor Guru
Joined: 14 Jan 2005 Posts: 5423 Location: St. Johns Mi
Posted: Sat Dec 12, 2020 2:35 am Post subject: Re: IH shredder |
I have one exactly like yours, but not in near as good a shape. No idea what model it is. There's no sign of markings left. I have mowed down some trees with it. Maybe why it's not in so good shape but it keeps going |
Back to top |
