Author |
Message |
rrman61 Long Time User
Posted: Wed Jan 13, 2021 12:44 pm Post subject: Slack noise in receiver hitch |
Is there a way to kill the receiver/receiver hitch noise from slack on my pickup ? Especially when hooked to a trailer? |
Back to top |
300jk Tractor Guru
Posted: Wed Jan 13, 2021 1:42 pm Post subject: Re: Slack noise in receiver hitch |
Do you mean between the ball and trailer hitch, pintle to trailer ring or just the noise in your truck receiver ? |
Back to top |
Janicholson Tractor Guru
Joined: 30 Jan 2004 Posts: 35784 Location: St. Cloud, MN
Posted: Wed Jan 13, 2021 1:43 pm Post subject: Re: Slack noise in receiver hitch |
Use a grade 8 bolt with a shank through both sides and then threads, instead of a pin, tighten it to binding, then double nut it. Or let it rust to solid. Jim |
Back to top |
Posted: Wed Jan 13, 2021 1:45 pm Post subject: Re: Slack noise in receiver hitch |
The noise in the truck receiver is there a way to get rid of the slack? |
Back to top |
WESnIL Long Time User
Posted: Wed Jan 13, 2021 2:14 pm Post subject: Re: Slack noise in receiver hitch |
No noise in mine. Use Jim's suggestion of a bolt with double nuts instead of a pin. Most take a 5/8" diameter bolt. I just use a Grade 5. |
Back to top |
Ken Macfarlane Tractor Guru
Load trailer with proper tongue weight.
Don't use a deep drop or rise hitch.
Thats about it, you can shim a receiver with poly banding straps for a trip but it doesn't last. |
Back to top |
Loosehandle Long Time User
Cut some shims if on the top or bottom wire them in. Sides drill hole. |
Back to top |
BRSnKY Regular
Posted: Wed Jan 13, 2021 2:15 pm Post subject: Re: Slack noise in receiver hitch |
There are store-bought cushions that last almost as long as a few wraps of cheap electrical tape. |
Back to top |
showcrop Tractor Guru
Joined: 13 Dec 2000 Posts: 28531 Location: Chester NH
Posted: Wed Jan 13, 2021 2:49 pm Post subject: Re: Slack noise in receiver hitch |
I have had receiver hitches on eight trucks switching around between three drawbars over 35 years and have never had any noise like the drawbar is moving in the receiver. I expect that lack of tongue weight would be a likely cause. |
Back to top |
Tony in SD Tractor Expert
Posted: Wed Jan 13, 2021 2:50 pm Post subject: Re: Slack noise in receiver hitch |
My new Ford pickup needed a sleeve to reduce receiver hole. If I didn’t use one I’m sure it would have made a lot of noise. |
Back to top |
DoubleO7 Tractor Guru
Posted: Wed Jan 13, 2021 3:38 pm Post subject: Re: Slack noise in receiver hitch |
Sometimes the receiver is a tad oversize, cause it is made up by the hitch company vs the steel mill.
The drawbar is usually close to exact cause it is 2" sq.
I have had a few that are sloppy when assembled.
My cure is to drill another hole in receiver tube on the bottom or side. Weld a nut over the hole.
Use a very short bolt slobbered up with nevrseez and use it as a set screw against the drawbar. |
Back to top |
jd man wis Long Time User
Posted: Wed Jan 13, 2021 3:39 pm Post subject: Re: Slack noise in receiver hitch |
Before I put my hich in the receiver I have a muffler clamp that's like 3 inches. I put the round part on the hitch that slides in and the other over the oUT side square part of the receiver and after I pin it I take and tighten down the clamp. Works good. |
Back to top |
tn terry t Tractor Expert
Posted: Wed Jan 13, 2021 4:05 pm Post subject: Re: Slack noise in receiver hitch |
CVPost-rrman61 wrote: | (quoted from post at 16:44:17 01/13/21) Is there a way to kill the receiver/receiver hitch noise from slack on my pickup ? Especially when hooked to a trailer? | amazon shows all kinds i typed in "anti rattle hitch tightener" dont know if they are worth a flip or not |
Back to top |
casecollectorsc Tractor Guru
Posted: Wed Jan 13, 2021 4:52 pm Post subject: Re: Slack noise in receiver hitch |
Newer pickups have a sleeve that goes in the receiver before you put the hitch in. Are you sure you are not missing this sleeve? |
Back to top |
J.Wondergem Tractor Guru
Posted: Wed Jan 13, 2021 5:52 pm Post subject: Re: Slack noise in receiver hitch |
Weld it. |
Back to top |
