Author |
Message |
MSS3020 Tractor Expert
Joined: 19 Mar 2002 Posts: 1640 Location: Firth, Nebraska
Posted: Fri Dec 18, 2020 8:58 am Post subject: chicken poop for hay field |
I live couple miles from egg/chicken place... they hire a guy that spreads poo for them..
Thinking of using on pasture where horses are and hay field..heard it is excellent fertilizer..
Any comments about this.. How long would I have to keep horses contained before letting out on treated field??
Scott |
Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 87626 Location: Lake of the Ozarks area of MO
Posted: Fri Dec 18, 2020 12:22 pm Post subject: Re: chicken poop for hay field |
Chicken manure tend to be hot so this time of year is the best time to put it on so rain and snow make it sock into the ground. I do that to my garden this time of year when I clean out the chicken houses |
Back to top |
Destroked 450 Tractor Guru
Joined: 31 Mar 2016 Posts: 6054 Location: Harned, Ky.
Posted: Fri Dec 18, 2020 2:33 pm Post subject: Re: chicken poop for hay field |
Can't really say about horses but I normally try to keep cows off of fields for 4-5 days, it isn't know to cause cows harm but they are known to eat some of the bigger chunks.
As for hay fields I hope you have good hay equipment, I have broiler houses and have been using chicken litter for over 12 years with out purchasing hardly any chemical fertilizer.
Putting 2-3 ton of litter per acre increased my hay yields 50% or more, when using chemical fertilizer my yields averaged 4 1/2 to 5 4x5 rolls per acre, now I'll average 7-8+ 4x5 rolls.
The most important thing is to have soil test done and adjust the amount spread according to test results, continued use at high application rates can cause nutrient levels to become to high thus locking the ground up which is worse than having poor ground, for that reason soil test are very important.
Chicken litter is some hot stuff, our's test out to were 1 ton is equal to 400lbs of triple 10 or 200 lbs of triple 19, that means spreading 3 ton of chicken litter per acre is about the same as applying 600lbs of triple 19 fertilizer per acre, that'll make the grass jump. |
Back to top |
Texasmark1 Tractor Guru
Posted: Tue Dec 22, 2020 6:41 pm Post subject: Re: chicken poop for hay field |
I saw it done one spring. Guy pulled a tank trailer with a slinger on it. What a mess and stunk to high heaven driving by for a couple of weeks. Results were awesome. No idea as to the stocking rules. |
Back to top |
Secret Squirrel Regular
Posted: Sat Dec 26, 2020 6:39 am Post subject: Re: chicken poop for hay field |
I had a neighbor that used it. He said it worked great, but a regular sicle mower would not cut it. It took a disc mower. |
Back to top |
ESVADuke Regular
Posted: Wed Jan 13, 2021 12:33 pm Post subject: Re: chicken poop for hay field |
it tends to be higher in P than N, but also adds lots of micronutrients. Just watch the P build up with repeated use. |
Back to top |
MJMJ Long Time User
Posted: Wed Jan 13, 2021 4:23 pm Post subject: Re: chicken poop for hay field |
Neighborhood will be cussing you for a while, but man does it grow hay. |
Back to top |
Tim in New York Long Time User
Joined: 05 Jan 2005 Posts: 615 Location: Upstate New York
Posted: Sun Feb 28, 2021 9:45 am Post subject: Re: chicken poop for hay field |
Chicken farmer I worked for as a kid had capacity for 16,000 birds in 3 barns, and one 15 acre field to spread the manure on. He raised broilers - 11 weeks from chick to shipping, He always planted and picked the corn field with a 1 row NI picker and Massey 150. Some years the corn would be 12' tall at least. Imagine it would have similar impact on just about anything you planted.
Tim |
Back to top |
