8N oil pump rebuild kit with early 9/16-wide gear
Bill Crowell
PostPosted: Sat Jan 16, 2021 8:15 am    Post subject: 8N oil pump rebuild kit with early 9/16-wide gear Reply to specific post Reply with quote
Calling TheOldHokie.
It arrived from Steiner Tractor in a clear plastic package (picture attached). The only label was a white tag with the part number, FDS384.
I have the impression that this oil pump repair kit is in somewhat scarce supply. Other suppliers said it was out of stock, and after I ordered this one Steiner's website indicated the same thing.
TheOldHokie
PostPosted: Sat Jan 16, 2021 10:12 am    Post subject: Re: 8N oil pump rebuild kit with early 9/16-wide g Reply to specific post Reply with quote
CVPost-Bill Crowell wrote:
(quoted from post at 12:15:58 01/16/21) Calling TheOldHokie.
<img src="/cvphotos/cvphoto71416.jpg">
Not in short supply as far as I know but between virus and tariffs parts availability is unpredictable. I found several places listing them. Before you use it slap a mic on those two gears - they should measure .561/.562.
TOH
Bill Crowell
PostPosted: Sat Jan 16, 2021 10:56 am    Post subject: Re: 8N oil pump rebuild kit with early 9/16-wide g Reply to specific post Reply with quote
Norm Sappenfield is going to rebuild the oil pump for me, Hokie, and I'm sure he will hold his usual tight tolerances.
TheOldHokie
PostPosted: Sat Jan 16, 2021 2:47 pm    Post subject: Re: 8N oil pump rebuild kit with early 9/16-wide g Reply to specific post Reply with quote
(quoted from post at 14:56:10 01/16/21) Norm Sappenfield is going to rebuild the oil pump for me, Hokie, and I'm sure he will hold his usual tight tolerances.
This is not a tolerance within his control. Its a product quality check that he may or may not think is neccessary. I have been burned enough times its the first thing i do when i get a kit. EVERY kit gets checked before it goes on the shelf and defective ones go straight back.
TOH
