Company Logo Auction Link (800) 853-2651
Primer Questions
relsem
PostPosted: Sun Feb 07, 2021 11:14 am    Post subject: Primer Questions Reply to specific post Reply with quote
I'm working on a spring painting plan for a 52 Ferguson.
I have been doing a lot of reading on degreasing, cleaning, prep, prime and paint but still have some questions.
- All sheet metal will be going to a body
shop for some metal work and paint.
- degrease and clean tractor.
- sand and wire wheel rust areas to bare
metal.
- prime ( my questions)
- Paint using an acrylic enamel.
Questions.
After cleaning rust areas to bare clean metal what should I prime thoes spots with to avoid flash rust while working on the rest of the tractor? I will be doing this over several day/weeks. If I use epoxy primer I'll miss the window and have to sand those areas before painting or is there an alternative I'm missing?
I wasn't planning on taking the entire thing to bare metal. What primer should I be considering to use to go over the cleaned and primed areas and the old paint that will work well with the acrylic enamel top coat?
Thanks in advance for your responses
Bob
glennster
PostPosted: Sun Feb 07, 2021 12:03 pm    Post subject: Re: Primer Questions Reply to specific post Reply with quote
if the body shop is going to do the paintwork, ask them what primer they want on it so it is compatible with the paint they are applying.
relsem
PostPosted: Sun Feb 07, 2021 1:03 pm    Post subject: Re: Primer Questions Reply to specific post Reply with quote
I'm applying the paint to the tractor. I'm looking at acrylic enamel. They are only doing the sheet metal.
glennster
PostPosted: Sun Feb 07, 2021 1:31 pm    Post subject: Re: Primer Questions Reply to specific post Reply with quote
use omni mp170 epoxy primer. here is a link
poke here
Stephen Newell
PostPosted: Tue Feb 09, 2021 5:25 am    Post subject: Re: Primer Questions Reply to specific post Reply with quote
I agree with glennster, have the body shop tell you what primer to use. They may even rather have a bit of rust than have you prime it.
Wreckmaster
PostPosted: Sun Feb 14, 2021 1:21 pm    Post subject: Re: Primer Questions Reply to specific post Reply with quote
Go to the hardware store and get some Phos-Pho. Its sold in a gallon or quart. Put it on the bare metal and it will keep it from rust for about 30 days. Its cheap and its clear and you can spray it on with a bottle sprayer. Thats what we use in our shop if we are working on something like that. It keeps from having to sand the primer back off. Remember if you are priming bare metal, you have to put etching primer or epoxy primer on bare metal or it will come off. There may be an industrial Direct to Metal paint option but if you are restoring and using an automotive paint to have good gloss, use etching or epoxy primer. Just my opinion.
ASEguy
PostPosted: Fri Mar 05, 2021 4:26 am    Post subject: Re: Primer Questions Reply to specific post Reply with quote
I used Picklex-20 for my bare metal parts that I stored for several months until I had everything ready to paint. It worked great.
showcrop
PostPosted: Fri Mar 05, 2021 5:44 am    Post subject: Re: Primer Questions Reply to specific post Reply with quote
I have some Oliver sheet metal that has been sitting for ten years since blasting and it has yet to "flash rust". I didn't run into it with my Ford but there was only a few weeks involved on that one.
DonTheNewby
PostPosted: Sat Apr 10, 2021 12:51 pm    Post subject: Re: Primer Questions Reply to specific post Reply with quote
If it's just been sanded and cleaned, is foregoing the primer fine and going direct to paint?
Or should epoxy primer be considered anyway?
showcrop
PostPosted: Sat Apr 10, 2021 1:13 pm    Post subject: Re: Primer Questions Reply to specific post Reply with quote
DonTheNewby wrote:
(quoted from post at 13:51:25 04/10/21) If it's just been sanded and cleaned, is foregoing the primer fine and going direct to paint?
You need to prime it only if you want your paint to stay on.
DonTheNewby
PostPosted: Sat Apr 10, 2021 1:29 pm    Post subject: Re: Primer Questions Reply to specific post Reply with quote
OMG, thats funny! Guess I'll be priming Very Happy
Credysis
PostPosted: Tue Apr 13, 2021 2:05 pm    Post subject: Re: Primer Questions Reply to specific post Reply with quote
CVPost-glennster wrote:
(quoted from post at 14:31:11 02/07/21) use omni mp170 epoxy primer. here is a link
poke here
This one is highly recommended.
catalina0029
PostPosted: Thu Apr 15, 2021 1:56 am    Post subject: Re: Primer Questions Reply to specific post Reply with quote
In keeping with this thread, do you then use a primer surfacer and sand? I shutter to think about sanding the engine and transmission.
Then do you seal it also or go direct to paint over the primer? I am talking about the tractor and not the sheet metal.
showcrop
PostPosted: Thu Apr 15, 2021 2:27 am    Post subject: Re: Primer Questions Reply to specific post Reply with quote
catalina0029 wrote:
(quoted from post at 02:56:21 04/15/21) In keeping with this thread, do you then use a primer surfacer and sand? I shutter to think about sanding the engine and transmission.
It is very rare to use a primer surfacer an anything but the outer sheet metal. I can think of two tractors that I have seen done with smooth shiny housings. You can go direct from your epoxy primer to your top coat, but just be mindful to stay in the time window.
Post new topic    Yesterday's Tractors Forum Index -> Paint and Bodywork All times are GMT - 8 Hours
