MM U302 PTO drive shaft #10A20396
panningbros
PostPosted: Mon Feb 15, 2021 9:33 am    Post subject: MM U302 PTO drive shaft #10A20396 Reply to specific post Reply with quote
Does anybody make a new #10A20396 PTO driveshaft (61" long) or rebuild old one? Or a decent used one? Thanks, Dave
molinegb
PostPosted: Mon Feb 15, 2021 1:09 pm    Post subject: Re: MM U302 PTO drive shaft #10A20396 Reply to specific post Reply with quote
U302 non super? There are new ones available. Expensive. Email open.
ubzbpuller
PostPosted: Tue Feb 16, 2021 7:44 pm    Post subject: Re: MM U302 PTO drive shaft #10A20396 Reply to specific post Reply with quote
Where are they available for late models? I just rebuilt mine on a 69 lp. Ill try to post pics of my fix for I couldnt find replacements. Drive hubs are on back order with no estimated date of availability.
Caseboy1
PostPosted: Wed Feb 17, 2021 8:57 pm    Post subject: Re: MM U302 PTO drive shaft #10A20396 Reply to specific post Reply with quote
Call Clint Stamm 785-325-2720. About seven years ago, I had him rebuild the splines on each end of one for a M670. Worked perfect. Still using it. They're really good people to deal with.
pa don
PostPosted: Mon Feb 22, 2021 6:23 am    Post subject: Re: MM U302 PTO drive shaft #10A20396 Reply to specific post Reply with quote
there is a cheap and easy fix for the hub p# seven one seven 486 5563 if you are interested
Alan K
PostPosted: Sat Feb 27, 2021 6:48 pm    Post subject: Re: MM U302 PTO drive shaft #10A20396 Reply to specific post Reply with quote
CVPost-pa don wrote:
(quoted from post at 07:23:45 02/22/21) there is a cheap and easy fix for the hub p# seven one seven 486 5563 if you are interested
Does what you are talking about work on other hubs?
pa don
PostPosted: Sun Feb 28, 2021 10:20 am    Post subject: Re: MM U302 PTO drive shaft #10A20396 Reply to specific post Reply with quote
to alan k no you can use a jet star hub can be turned down to 302 match 302 hub it is simple we did it on a old lath and angle grinder in a farm shop only if you at them side by side it is simple
