185 brakes
Brokentractor71
PostPosted: Fri Apr 09, 2021 8:11 am    Post subject: 185 brakes Reply to specific post Reply with quote
I'm installing the right hand
brake. I have everything new
including the 4 steel balls. My
question is. Do I put grease or
anything on the 4 steel balls or
install them dry?
luckey
PostPosted: Fri Apr 09, 2021 2:01 pm    Post subject: Re: 185 brakes Reply to specific post Reply with quote
Put some never seize on them also make sure tolerances are correct
DrAllis
PostPosted: Fri Apr 09, 2021 7:22 pm    Post subject: Re: 185 brakes Reply to specific post Reply with quote
Also anti-seize the threads on the brake rod so it will adjust down the road years from now.
Donald in MN
PostPosted: Sun Apr 11, 2021 12:36 pm    Post subject: Re: 185 brakes Reply to specific post Reply with quote
i install them dry if you use grease or never seize on them it attracts dust and gums everything up
Eldon (WA)
PostPosted: Sun Apr 18, 2021 7:33 pm    Post subject: Re: 185 brakes Reply to specific post Reply with quote
CVPost-Donald in MN wrote:
(quoted from post at 13:36:35 04/11/21) i install them dry if you use grease or never seize on them it attracts dust and gums everything up
I agree, no need to put anything on the balls...you don't want dust and dirt sticking to them.
DrAllis
PostPosted: Mon Apr 19, 2021 4:09 am    Post subject: Re: 185 brakes Reply to specific post Reply with quote
After 45+ years of putting antiseize or wheel brg grease lightly in the ball pockets, I've never seen any problems. I have however seen lots of rusty balls and pockets that have caused trouble. Remember, I have relined brakes in some tractors three times in 45 years and will continue to coat the balls and pockets with some sort of lube. Suit yourself.
