Allis CA Cutout to Voltage Regulator
AndrewJS
PostPosted: Mon Apr 19, 2021 12:38 pm    Post subject: Allis CA Cutout to Voltage Regulator Reply to specific post Reply with quote
Hello,
Posted a while back about my CA. Got it running pretty well and have used a back blade I've got with it to clean up some hedgerows around the property to good effect. I am now trying to sort out the electrical system. I don't believe the generator is charging the battery -- this is difficult to confirm however as my ammeter never moves and the hi-lo charge switch is seized in the first position. While running I checked the terminals on the generator (F, A, and both on the cutout) and had ~6 or ~7 volts on all except the F, which was low (about 2 volts). From reading online I believe this may indicate a faulty cutout. If this is the case, would it be wise to remove both the old switch and the cutout and replace with a 2-position switch and a voltage regulator? This seems to be a much more foolproof system and a decent upgrade if I'm going to have to replace both anyway.
Thanks.
steve(ill)
PostPosted: Mon Apr 19, 2021 3:43 pm    Post subject: Re: Allis CA Cutout to Voltage Regulator Reply to specific post Reply with quote
F is the ground wire... A is the hot wire... The ground wire goes to the light switch to be grounded.. to BYPASS that for a test, run a jumper from the F terminal to ground and then see if the A terminal has output ( above 7 volts) ... If so, your light switch is the problem...
Next, measure the OUTPUT from the cutout to see if it is CLOSED and the power from A is going thru the cutout.. You should get the same volts ( above 7) out OUTPUT and you do on the INPUT.
jimtrs
PostPosted: Thu Apr 22, 2021 2:44 pm    Post subject: Re: Allis CA Cutout to Voltage Regulator Reply to specific post Reply with quote
CVPost-AndrewJS wrote:
(quoted from post at 16:38:54 04/19/21)
.... If this is the case, would it be wise to remove both the old switch and the cutout and replace with a 2-position switch and a voltage regulator? This seems to be a much more foolproof system .....
My experience is that is is difficult, if not near impossible to get a reliable good working 6 volt regulator.
phil(va)
PostPosted: Tue May 04, 2021 12:47 pm    Post subject: Re: Allis CA Cutout to Voltage Regulator Reply to specific post Reply with quote
While running you could put volt meter across battery terminals and check if charging or not. Should be about 7 volts if it's 6 volt system.
