TO30 Wiring Diagram
glenmorebuckman
PostPosted: Sun May 16, 2021 8:18 pm    Post subject: TO30 Wiring Diagram Reply to specific post Reply with quote
I'm not very Knowledgeable when it comes to wiring so I could use some help on this. Here is a diagram I made up. Can someone look it over and see if it's correct?
Jim.ME
PostPosted: Mon May 17, 2021 2:06 am    Post subject: Re: TO30 Wiring Diagram Reply to specific post Reply with quote
CVPost-glenmorebuckman wrote:
(quoted from post at 00:18:25 05/17/21) I'm not very Knowledgeable when it comes to wiring so I could use some help on this. Here is a diagram I made up. Can someone look it over and see if it's correct?
<img src=/cvphotos/cvphoto88619.jpg>
You need an incandescent indicator light, a diode, or a resistor in the wire between the I terminal of the key switch and the #1 terminal of the alternator. If you don't have one of those the alternator will back feed the system and it will continue to run after you turn the key off. Below is a diagram from the Ferguson site showing the proper wiring from the I terminal and info on the diode, light, or resistor required.
http://fergusontractors.org/nfs/wp-content/uploads/electrical/Delco-2-wire-Alternator.pdf
rvirgil_KS
PostPosted: Mon May 17, 2021 6:01 am    Post subject: Re: TO30 Wiring Diagram Reply to specific post Reply with quote
Move the diode to #1 pin on edge of alternator as Jim says. White band toward alternator.
There should be no diode between alternator output and ammeter. As it is now the system will not charge. The diode is a one way device, and with white marker toward alternator it will block charge from going to ammeter.
Rest of wiring looks correct
glenmorebuckman
PostPosted: Mon May 17, 2021 11:53 am    Post subject: Re: TO30 Wiring Diagram Reply to specific post Reply with quote
Whoops!!! I already knew that but screwed up the drawing somehow!! Thanks for catching that guys.
Billy
Steve@Advance
PostPosted: Mon May 17, 2021 6:55 pm    Post subject: Re: TO30 Wiring Diagram Reply to specific post Reply with quote
Looks good except for the diode as said.
Do you know what coil it has?
If it's a true 12v (3 ohm) coil you are good.
If it's a 6v (1.5 ohm) or says resistor needed, it will need a 1.5 ohm resistor on the ignition side of the primary.
glenmorebuckman
PostPosted: Mon May 17, 2021 7:35 pm    Post subject: Re: TO30 Wiring Diagram Reply to specific post Reply with quote
Yes, its a 12volt coil. Just purchased it last week!
