Question on clearcoat
chuck machinist
PostPosted: Mon May 17, 2021 9:22 am    Post subject: Question on clearcoat Reply to specific post Reply with quote
I shot five coats of flambeau red on my DC4, and this evening I Will lightly rub the sheet metal before I put my clearcoat on. Question is what would be a reasonable time before I apply my clearcoat? Thanks in advance .Chuck machinist. im using second dimension acrylic urethane enamelFor my paint
Stephen Newell
PostPosted: Mon May 17, 2021 2:31 pm    Post subject: Re: Question on clearcoat Reply to specific post Reply with quote
Tried to reply this morning but lost the internet. Do it soon if you haven't already. Try it on a small spot first and see if it lifts the base coat before you do very much.
chuck machinist
PostPosted: Tue May 18, 2021 2:45 am    Post subject: Re: Question on clearcoat Reply to specific post Reply with quote
I appreciate that Steve. I will test that on the inside of the fenders that I painted also Chuck Machinist
Stephen Newell
PostPosted: Tue May 18, 2021 6:05 am    Post subject: Re: Question on clearcoat Reply to specific post Reply with quote
You know the rattle can paint where it says put all the coats on within an hour or wait 7 days. A clear coat will sometimes do that to a base coat. It can make the paint wrinkle up like you put paint stripper on it.
Goose
PostPosted: Wed May 19, 2021 9:09 am    Post subject: Re: Question on clearcoat Reply to specific post Reply with quote
I've worked with a lot of automotive base/clear systems, and 30 minutes between base and clear is a good rule of thumb.
My usual routine is, I shoot the base, and by the time I clean up the base coat gun, mix the clear, and check out my clear coat gun, enough time has elapsed to go ahead and shoot the clear.
The actual bottom line is, read what it says on the paint can.
chuck machinist
PostPosted: Sun May 30, 2021 2:23 pm    Post subject: Re: Question on clearcoat Reply to specific post Reply with quote
Thanks Goose. I appreciate you and Steve's comments. I'll get some final pics posted tomorrow. Chuck Machinist
chuck machinist
PostPosted: Sun May 30, 2021 2:27 pm    Post subject: Re: Question on clearcoat Reply to specific post Reply with quote
I found these just now. Enjoy! CM
KayBur
PostPosted: Thu Jun 03, 2021 12:41 am    Post subject: Re: Question on clearcoat Reply to specific post Reply with quote
The tractor looks like new. You did a great job. Fully prepared for field work!
Post new topic    Yesterday's Tractors Forum Index -> Paint and Bodywork All times are GMT - 8 Hours
