Remote Valve Testing for 30 and 70 Series
1370rod
PostPosted: Mon May 17, 2021 9:12 am    Post subject: Remote Valve Testing for 30 and 70 Series Reply to specific post Reply with quote
I put this simple system together years ago. It allows you to check out the pressure settings and check for leakage BEFORE the valve is reinstalled. Case sold a manual hand pump for this same procedure that works better because of the increased oil flow per pump but I never had a chance to buy one yet. So if you are like me and dont have one,this works fine, Rod.
451 CUBES
PostPosted: Mon May 17, 2021 9:44 am    Post subject: Re: Remote Valve Testing for 30 and 70 Series Reply to specific post Reply with quote
Nice. Thats the way to do it. Sure beats pulling the valve back off because of an assembly error with the relief o-rings. Been there. Should be able to check the thermals are holding as well? Feed the hand pump in to the outlet ports and tee in the guage or watch for leakage?
jim_uny
PostPosted: Mon May 17, 2021 1:28 pm    Post subject: Re: Remote Valve Testing for 30 and 70 Series Reply to specific post Reply with quote
thank you for that pic. a real diagnostic solution
1370rod
PostPosted: Mon May 17, 2021 6:20 pm    Post subject: Re: Remote Valve Testing for 30 and 70 Series Reply to specific post Reply with quote
Yep they can be tested this way and watch for pressure drop, just have to move the gauge to the other outlets, Rod.
Don Rudolph
PostPosted: Mon May 17, 2021 6:35 pm    Post subject: Re: Remote Valve Testing for 30 and 70 Series Reply to specific post Reply with quote
A picture is worth a thousand words, Rod. Thanks for posting this. Don
EP
PostPosted: Tue May 18, 2021 3:40 am    Post subject: Re: Remote Valve Testing for 30 and 70 Series Reply to specific post Reply with quote
Nice. I made an injector tester using a porta power.
1370rod
PostPosted: Tue May 18, 2021 4:39 am    Post subject: Re: Remote Valve Testing for 30 and 70 Series Reply to specific post Reply with quote
Don I thought of you when a customer carried in the valve and wanted it tested, I was sure you would appreciate the photo, Rod.
4435
PostPosted: Tue May 18, 2021 7:00 pm    Post subject: Re: Remote Valve Testing for 30 and 70 Series Reply to specific post Reply with quote
Years ago I put something together bearing a crude resemblance. Used my bale sticker pump, must have done what I needed. This was on the 970. Would have more volume for sure. BUT not near as nice as Rods. Tom
