Author |
Message |
red bullet Regular
Posted: Thu Mar 14, 2013 8:19 pm Post subject: Hydraulic MFWD for 70 series |
Anyone know where a hyd drive front axle ( Mud Hog) is for a 70 series case? I am looking at buying a 1070 and would like to install one and play with it a little. It would just be my yard tractor. |
Back to top |
casepower970 Regular
Joined: 09 Mar 2013 Posts: 187 Location: Waterloo, IA
Posted: Thu Mar 14, 2013 9:34 pm Post subject: Re: Hydraulic MFWD for 70 series |
If you were doing tillage I would reccomend it.. |
Back to top |
1370rod Tractor Guru
Posted: Fri Mar 15, 2013 3:35 am Post subject: Re: Hydraulic MFWD for 70 series |
I know for a period of time the hyd fwd was available for the 90 series, but I don't think they ever offered it on the 70 series. Main reason would have been the limitations of the open center hyd system used on the 70's. Such a system on them I believe would cause a lot of heat build up in the hyd's and shorten the life of the gear type pump. Just my two cents worth, Rod. |
Back to top |
RGMartin Tractor Guru
Posted: Fri Mar 15, 2013 4:00 am Post subject: Re: Hydraulic MFWD for 70 series |
I think Loren was somehow involved the development of these. If I recall correctly, there was a separate pump mounted out in front of the tractor. Then a bunch of fancy valving integrated into the powershift. |
Back to top |
Adirondack case guy Tractor Guru
Posted: Fri Mar 15, 2013 4:24 am Post subject: Re: Hydraulic MFWD for 70 series |
Rod,
I was fortunate enough to work with Bill Simpson, via a lot of phone calls to get this project done. This 1070 was the prototype, which lead to the 90 series HFWA. The standard hyd. pump on the 70's were not suited to drive the Mud Hog, so a front mounted pump was incorperated. The 90 seties tractors had a pump that would handle the MH.
I ordered this 1070 with a ROPS, but when we sold it we had to make it an open station so the customer could get it in the manure shed. We never sold another 70 series, but we went on to sell two 22's and a 2090. Then the MFD's came out.
Loren
Back to top |
casecollectorsc Tractor Guru
Posted: Fri Mar 15, 2013 5:19 am Post subject: Re: Hydraulic MFWD for 70 series |
Do you know where that tractor is today?? Is it still operational? |
Back to top |
Posted: Fri Mar 15, 2013 6:15 am Post subject: Re: Hydraulic MFWD for 70 series |
Yes, it is still working on the farm where we sold it, about 20 miles from me. The pic was taken the summer of 2011.
Loren |
Back to top |
Posted: Fri Mar 15, 2013 9:22 am Post subject: Re: Hydraulic MFWD for 70 series |
Thanks Loren, Thats neat to know, so this is truly one of a kind? |
Back to top |
Posted: Fri Mar 15, 2013 11:52 am Post subject: Re: Hydraulic MFWD for 70 series |
Rod,
I don't know how many of these kits were built. We had the tractor sent from Case to Mud Hog. They built and installed the unit, and when they finished, (about 4 months) Case Fleet picked it up and delivered it, and the leftover front end parts to our dealership. It arrived here and we preped it and took it to the NYS Farmshow and Field Days, where it was debuted in the Case exibit, the fall of 77.
Loren |
Back to top |
D-C-741 Long Time User
Posted: Fri Mar 15, 2013 8:19 pm Post subject: Re: Hydraulic MFWD for 70 series |
Saw a 1370 in a dealers lot in Western NY That Had HYD Front Drive On It a Few Years Ago.CASE Sent One [ 1070 w Cab & AC /It had the HYD Front Drive/ They only had it about a Week before it was Sold ] To S C HANSEN IN Horseheads,NY [long time CASE Dealer ].It was one of the very last 70 series that they had as the 90 series were out. |
Back to top |
NickatKY Tractor Expert
Posted: Sat Oct 29, 2016 8:11 am Post subject: Re: Hydraulic MFWD for 70 series |
The topic post your dream tractor came up on Facebook. This 1070 would be my first pic.
Nick |
Back to top |
