Cat 3204 running rough
Goto page Previous  1, 2
dpendzic
PostPosted: Sat Mar 30, 2013 6:55 pm    Post subject: Re: Cat 3204 running rough Reply to specific post Reply with quote
I am going to pull my transfer pump apart as a cat mechanic told me the check valves and/or springs inside can get gunked up and the springs can corrode and break.said it was common on the Mitsubishi transfer pumps.
RodinNS
PostPosted: Sun Mar 31, 2013 12:22 pm    Post subject: Re: Cat 3204 running rough Reply to specific post Reply with quote
If the screen is staying clear and you have good flow to the transfer pump then I'd say the transfer pump is the problem... Check for a bleeder on the filter housing if there's none on the pump manifold. Open the bleeder and see if it will shoot fuel when you crank. It should...
Rod
Page 2 of 2
