Case 580B
daviddg
PostPosted: Fri May 03, 2013 2:07 pm    Post subject: Case 580B Reply to specific post Reply with quote
Wondering where the master cylinder filler cap for the brakes on a Case 580B is located. Thanks to someone who can tell me the location.
Case Nutty 1660
PostPosted: Fri May 03, 2013 2:39 pm    Post subject: Re: Case 580B Reply to specific post Reply with quote
580B tractors have mechanical brakes
daviddg
PostPosted: Fri May 03, 2013 2:47 pm    Post subject: Re: Case 580B Reply to specific post Reply with quote
So what do we need to do to fix the braking problem?
Joe (Wa)
PostPosted: Fri May 03, 2013 3:07 pm    Post subject: Re: Case 580B Reply to specific post Reply with quote
Sheeeesh 580B has BRAKES??? When did Case start putting brakes on their tractors?
Joe
Case Nutty 1660
PostPosted: Fri May 03, 2013 6:15 pm    Post subject: Re: Case 580B Reply to specific post Reply with quote
sounds like you need to pull the brakes and see what needs replacing, I can post you breakdowns on where you can start looking, there is also a adjustment under the tractor on the brake linkage, basic;ly you will need to replace the balls/springs and lining wear parts,,, will try to post what you need if no one else has them handy cnt
J Miley
PostPosted: Sun May 05, 2013 4:13 pm    Post subject: Re: Case 580B Reply to specific post Reply with quote
If you get in to it and need some parts I might have some I could let you have reasonable. I'm putting brakes on a 580CK right now and acquired some extra parts. The left side was corroded up pretty bad. The right side I think the linkage just needs freed up.
