Author |
Message |
chuck machinist Tractor Guru
Joined: 05 Jul 2011 Posts: 3573 Location: chesapeake va.
Posted: Mon Oct 14, 2013 5:21 pm Post subject: AUTOLITE MAX 4095 starters |
Any leads on where I may find a 10 tooth starter assembly for a Autolite Max 4095 for my 411 ? |
Back to top |
jstpa Regular
Posted: Mon Oct 14, 2013 6:05 pm Post subject: Re: AUTOLITE MAX 4095 starters |
That is a really common old drive . Any starter rebuilder will either have it or can get it. If you cant find one email me and I'll get you one. jstpa |
Back to top |
Posted: Tue Oct 15, 2013 1:13 pm Post subject: Re: AUTOLITE MAX 4095 starters |
Thanks for the information on the starter, your right, it is still available and quite common. My rebuild will be drastically reduced.. the starter drive is roughly priced at $40.00.Thanks! |
Back to top |
John Saeli Tractor Guru
Posted: Tue Oct 15, 2013 5:02 pm Post subject: Re: AUTOLITE MAX 4095 starters |
What did you decide on the nose cone? |
Back to top |
Posted: Tue Oct 15, 2013 5:14 pm Post subject: Re: AUTOLITE MAX 4095 starters |
Ill have my hands on a starter carcass later this week John and then I will do a rebuild. At my leisure I will reweld the nose cone and save her for a spare. I will post some pics of the ring gear later in the week, when I get out to the farm. First glance does not look too worn .. I will take a small pry bar and rotate the entire ring gear for a good look! |
Back to top |
Posted: Wed Oct 16, 2013 3:58 am Post subject: Re: AUTOLITE MAX 4095 starters |
Usually, the ring gear will be burred in 3 areas. I've spent many hours on tractors & old trucks, reaching thru the starter hole w/ a file, filing burred teeth because I was too lazy to fix them correctly. |
Back to top |
mEl Tractor Guru
Posted: Wed Oct 16, 2013 4:13 pm Post subject: Re: AUTOLITE MAX 4095 starters |
John Saeli wrote: | (quoted from post at 04:58:27 10/16/13) Usually, the ring gear will be burred in 3 areas. I've spent many hours on tractors & old trucks, reaching thru the starter hole w/ a file, filing burred teeth because I was too lazy to fix them correctly. |
Check the armature for straight, when the nose breaks from broken gears often it tweaks the armature shaft some.
We welded a nose three times using stainless wire and a red preheat with a rosebud torch cooling it slowly. every time it broke it was at a different spot, the SS held perfectly.
I won't even tell you what DC engine we were trying to start!!! |
Back to top |
