JD 4240 loosing power
Tim14167
PostPosted: Sat Oct 26, 2013 10:18 am    Post subject: JD 4240 loosing power Reply to specific post Reply with quote
I took the 4240 down the road today and immediantly noticed that the tractor seemed like it was starving for power. It got up to 1900rpm"s and some what leveled off there for a few seconds, it eventually got up towards 2300rpms. Once it hit the hill it was gutless. I had to down shift from D4 to D3 and it struggled to make it to the top. Normally I can go up this hill in D4 with no hesitation what so ever. Needless to say I turned around and got back home. Now, last spring I had the fuel pump and injectors rebuilt, I even took the extra measures and removed the fuel tank and cleaned it out. When I got back I looked at the fuel filter (glass type) and it looked good, I could not see any water or debirs inside....Any help would be greatly appreciated.
Thansk in advance.
Bob
PostPosted: Sat Oct 26, 2013 10:28 am    Post subject: Re: JD 4240 loosing power Reply to specific post Reply with quote
"looked good" does not mean the filter is not getting clogged.
Personally, I would begin by hooking up a gauge and monitoring transfer pump pressure after the filters.
rrlund
PostPosted: Sat Oct 26, 2013 11:33 am    Post subject: Re: JD 4240 loosing power Reply to specific post Reply with quote
My 4040 acted like that when the lift pump went bad.
Bob Bancroft
PostPosted: Sat Oct 26, 2013 1:06 pm    Post subject: Re: JD 4240 loosing power Reply to specific post Reply with quote
Change the filter anyhow. Seemed like every time I helped a neighbor, running his 4240, I had to change the filter. That filter is pretty, but I'm thinking there isn't nearly the filtering media as there might be in a spin on.
Tx Jim
PostPosted: Sat Oct 26, 2013 1:45 pm    Post subject: Re: JD 4240 loosing power Reply to specific post Reply with quote
Bob Bancroft wrote:
(quoted from post at 17:06:20 10/26/13) Change the filter anyhow. Seemed like every time I helped a neighbor, running his 4240, I had to change the filter. That filter is pretty, but I'm thinking there isn't nearly the filtering media as there might be in a spin on.
IMHO the rectangular fuel filters are far superior to the spin on fuel filters. BUT the cheapest.easiest diagnostics would be to change fuel filter and check for good fuel flow from the tank to inj pump.
Bob Bancroft
PostPosted: Sat Oct 26, 2013 2:00 pm    Post subject: Re: JD 4240 loosing power Reply to specific post Reply with quote
Far superior? In what way?
Two things I recall when they first appeared was exploding when pressurized with hand primer pump, and company recommending reversing the clamp to minimize sucking air around one of the rubber seals.
Maybe our different experiences are the difference between NY and TX weather!
John in MD
PostPosted: Sun Oct 27, 2013 1:02 am    Post subject: Re: JD 4240 loosing power Reply to specific post Reply with quote
Did you check air filters? Remember to check the inner one, not just the outer filter.
Tx Jim
PostPosted: Sun Oct 27, 2013 2:43 am    Post subject: Re: JD 4240 loosing power Reply to specific post Reply with quote
Bob Bancroft wrote:
(quoted from post at 18:00:10 10/26/13)
I remember a very few glass filters exploding from over-pressurization. I also remember a lot of older 3020/4020 that were changed over from round to rectangular filters. If they are so troublesome as you state how come they were factory installed so many years? I know JD utilized rectangular fuel filters from '73-'93
Bob Bancroft
PostPosted: Sun Oct 27, 2013 2:57 am    Post subject: Re: JD 4240 loosing power Reply to specific post Reply with quote
I don't know why they were used. Promotion on Roosa Master's part? I didn't think they were, nor did I state that they were terribly troublesome. It's just that they had issues that other filters never had. I recall another incident where a customer pulled one off, shook the crud out of it, put it back on, and proceeded to ruin his injector pump. I suppose that could have been done with any filter. But I think that with the clip mounting, and see through design, it lent itself to this kind of abuse. Didn't they later use a different, opaque material for the housing?
You stated they were "far superior". I would like to know why.
Tx Jim
PostPosted: Sun Oct 27, 2013 4:32 am    Post subject: Re: JD 4240 loosing power Reply to specific post Reply with quote
Bob Bancroft wrote:
(quoted from post at 06:57:52 10/27/13) Didn't they later use a different, opaque material for the housing?
Later rectangular filters were metal instead of glass. Also the later ones such as my 4255 had different attaching clips. The reason in my mind the rectangular were superior because of the ease to change filters with no need for any tools.
Please read the sentence at the bottom that states rectangular filters have both a primary & secondary stage that some other filters don't have.
larryanderson
PostPosted: Mon Oct 28, 2013 2:14 am    Post subject: Re: JD 4240 loosing power Reply to specific post Reply with quote
Fuel filters and air filters have solved many problems with lack of power.
