Removing the injector sleeves on a IH D310 engine
hfarmall
PostPosted: Mon Jan 01, 2018 10:29 am    Post subject: Removing the injector sleeves on a IH D310 engine Reply to specific post Reply with quote
Hi, what tool can you use to remove the injector sleeves on a d310.
THANKS,
430WLPG
PostPosted: Mon Jan 01, 2018 11:11 am    Post subject: Re: Removing the injector sleeves on a IH D310 engine Reply to specific post Reply with quote
Seems like you use a 7/8 tap cut threads in use and use a
7/8 bolt hooked on a slide hammer and put something in the
bottom of the sleeve to keep shavings out of cylinder
430WLPG
PostPosted: Mon Jan 01, 2018 4:47 pm    Post subject: Re: Removing the injector sleeves on a IH D310 engine Reply to specific post Reply with quote
There is a special tool to install them it's the shape of the injector a it drives them in at the taper at the bottom
hfarmall
PostPosted: Mon Jan 01, 2018 5:13 pm    Post subject: Re: Removing the injector sleeves on a IH D310 engine Reply to specific post Reply with quote
Do you know where I could locate one of those tools.
Thanks for you help
used red MN
PostPosted: Mon Jan 01, 2018 10:10 pm    Post subject: Re: Removing the injector sleeves on a IH D310 engine Reply to specific post Reply with quote
I would post this on the Farmall and IH board. Most likely get an answer there.
