My D Case Working
Ron Sa
PostPosted: Mon Apr 07, 2014 7:03 am    Post subject: My D Case Working Reply to specific post Reply with quote
Here is a link to video clips of my D Case working in 2006. Turn on the sound.
M D Case Working
Ron Sa
PostPosted: Mon Apr 07, 2014 7:29 am    Post subject: Re: My D Case Working Reply to specific post Reply with quote
History of my D Case.
As I recall, this 1949 tractor was 19 years old when my brother Carl got it in 1968 when he was age 25 and struggling in his early years of farming near Harveyville, Ks. He paid only $50 for it because the block was cracked behind the manifold from freeze up and because it had no hydraulics. It had big bore aluminum pistons. It would plow much faster that his other tractor—a 1952 B John Deere.
Yup, it has bar axles so it’s not a D. It is a modified DC3. It was modified about 45 years ago. We call it a D because it looks like a D.
Dad had discovered that his 1938 C Case and his 1935 B John Deere was a compatible pair for farming. The Case was the powerhouse and the little John Deere was nimble for the light work. Like father like son, Carl saw this combination work for dad so Carl’s Case became the powerhouse and his 52 B John Deere was well suited for the light work.
A DC3 was less friendly to drive than dad’s C Case. We know that all brands, with narrow fronts before power steering, were difficult to steer. Plow furrows could be dangerous with the narrow front. Many a thumb got broke by the steering wheel. Deere tried Roll-O-Matic. Dad’s C Case had no such steering problems. This influenced Carl to put a D front axle under his DC3.
Carl also chose to change to smaller diameter rear tires. Why do that? For plowing and disking, the DC badly needed a speed between 2nd and 3rd. Generally speaking, the D and DC would loaf in 2nd with three bottoms but 3rd tended to be overload. Putting DC final drive sprockets into a D slowed down 3rd into the sweet spot for plowing and disking . The tractor in the video above has that sweet spot because it has the DC final drive sprockets and small diameter rear tires.
Some of the video is running in 2nd because it was running with two slower tractors that are mostly edited out of the video. The land wheel needed weights but nothing was available in my stash that would fit the modified rear wheel. This modified tractor is a better plow tractor than any of my standard DCs. It’s the most fun to run of any of my herd of antiques. My DC AWF is a close second.
This D plowed and disc the first 10 years that Carl used it. The second 10 years, it was dedicated mainly to grind hog feed using the PTO. He had a BIG hog operation. It would start at any temperature and the hand clutch is a dream for PTO stationary work. In more recent years, I use it on my grain auger. The reason he quit using this tractor was because he got out of the hog business and no more feed to grind. Bigger tractors were then doing the heavy tillage. It sat unused for about 15 years before I got the tractor. Carl was intending to junk it unless I wanted it. The junk man lost. It was trucked 460 miles to my place in central Illinois in April 2003.
All I had to do to the engine’s internals was replace the front rod because the babbitt was marginal. It does not smoke or use oil. I fixed and painted it about 2005 when it was 56 years old. The video clips were taken in 2006.
For its future, I am working with others to secure a corner display, as part of a large AG machinery museum. Tentatively, the display will include this family heirloom along with several other tractors that are my family’s heirlooms. The tentative plan is to have the Ag museum near I-74 for easy access off one of the four exits between Galesburg, Illinois and Peoria Illinois. We want the museum to include reality. Reality is this. A lot of Ag equipment got modified by creative farmers and other mechanics to make Ag equipment better. Reality tends to showcase the farmer’s creativeness.
Company CEO’s were not the leaders in AG innovation. The farmers were. My dad had to innovate because we were poor.
wilson ind
PostPosted: Mon Apr 07, 2014 9:02 am    Post subject: Re: My D Case Working Reply to specific post Reply with quote
I have a good looking dc foot clutch adj wide front with rare nose weight. freast paint Its presently in Wyoming Ill very close to you. It will go to my son in Wyoming ill at my death. However it is mine to do as I like till my death. It would possibly be very good for a display for you. The only use I might do is parade in your area
wilson ind
PostPosted: Mon Apr 07, 2014 9:04 am    Post subject: Re: My D Case Working Reply to specific post Reply with quote
I should add I have had the tractor since 1972. It was my second DC. Engine totally rebuilt I challenge one to hear a smoother dc engine.
Don Rudolph
PostPosted: Mon Apr 07, 2014 3:45 pm    Post subject: Re: My D Case Working Reply to specific post Reply with quote
Ron,
Good for you for saving that piece of family history. I appreciate the description of how your tractor was modified to better suit its purpose. That is awesome on-farm engineering, as far as I'm concerned.
I hope the museum idea comes alive for you. Good Luck! Don
LME
PostPosted: Mon Apr 07, 2014 5:36 pm    Post subject: Re: My D Case Working Reply to specific post Reply with quote
Picture of my DC4
Ron Sa
PostPosted: Tue Apr 08, 2014 2:48 am    Post subject: Re: My D Case Working Reply to specific post Reply with quote
Hey Larry, Got your email. Good to hear from old friends. That is a nice looking DC4. Got any history of it?
A few years back about 2004, Carl was looking to buy a DC4 to play with. He knew of one in the Burlingame area that a widow lady owned but she would not sell it at that time. Is yours that tractor? Carl found one up NE somewhere around St Joe as I recall.
Nice looking restoration with fenders, decals and all. I notice the throttle lever looks to be about 1952 vintage. Carl's 49 has notches. I like the oil dipstick.
None of my tractor projects got completely finished. They got repaired, stripped down, sand blasted, primed, and one coat of original paint. As we know, the newer paints are the DuPont gloss. The original paint, with a flat texture, was my choice but my source for original paint went away.
Also, my energy and interest to finish the exteriors is greatly diminished. I am thinking the next owners can finish the exteriors or use them as is---either a show tractor or a work tractor.
My goal when I started fixing up old tractors was to rescue old tractors from the junk man and preserve them. I consider them all preserved even though they are not finished. I guess I met my goal.
LME
PostPosted: Tue Apr 08, 2014 3:41 am    Post subject: Re: My D Case Working Reply to specific post Reply with quote
I got the tractor out by McPherson, a young man(teenager) did the restore. All I know about it is that he got it from a neighbor. They said it's main job was to run a irrigation pump, ran on natural gas. It was headed for the junk yard when he got it.
Nice to hear from you.
Larry
Adirondack case guy
PostPosted: Tue Apr 08, 2014 3:47 am    Post subject: Re: My D Case Working Reply to specific post Reply with quote
Looks like a Teddy Rosevelt tractor!! "rough riding SOB"
HeHe,
Loren
