WC 12 volt conversion
48C-MAN
PostPosted: Wed Apr 30, 2014 9:40 am    Post subject: WC 12 volt conversion Reply to specific post Reply with quote
I am converting my 6v pos ground to a 12v neg ground. It has a ignition switch and solenoid not the oe rocker. Should I change the solenoid or any of the wiring for the ignition along with the regular items (coil batt gen light bulbs etc)? Thanks for any help with this.
John T
PostPosted: Thu May 01, 2014 5:34 am    Post subject: Re: WC 12 volt conversion Reply to specific post Reply with quote
Since the solenoid isn't engaged and drawing excess current (due to twice the voltage applied) for a very long time, it "could" maybe might lol last a long time. However, it would be easy to add a series voltage dropping power rated resistor in series to reduce the 12 volts down to 6 orrrrrrrrrr fairly cheap n easy to just get a 12 volt solenoid if and when an old 6 volt burned out.
If changing polarity the coil polarity also needs to be changed as well as any ammeter leads so it dont read bass ackwards.
You can EITHER add a series voltage dropping (12 down to 6) Ballast Resistor to the 6 volt coil OR get a new full true 12 volt coil no ballast required
The old 6 volt starter will work and still turn same direction regardless of polarity, however, it can be a bit tougher on starter drives/gears etc when using 12 volts on a 6 volt starter. Ive done that with no problems however and dont let them crank on and on and on to risk overheating.
John T
steve(ill)
PostPosted: Thu May 01, 2014 2:18 pm    Post subject: Re: WC 12 volt conversion Reply to specific post Reply with quote
New solenoid and 12v coil would be a good idea. Old 6 v generator had a cutout ? NEw 12 v needs a voltage regulator and an extra wire or two..
