445 Governor
majorlucas
PostPosted: Thu May 08, 2014 9:25 am    Post subject: 445 Governor Reply to specific post Reply with quote
After trying everything else, we found the governor was way out of adjustment on the 445. So we shortened the rod and really improved performance. But a 2-bottom is still all she wants.
What is the best way to adjust the governor properly? Thanks Marty
Captainhookerus
PostPosted: Thu May 08, 2014 12:09 pm    Post subject: Re: 445 Governor Reply to specific post Reply with quote
Unhook the rod from gov to carb. Pull throttle lever to wide open position. Adjust rod so it will go back into carb lever or gov arm which ever you end you removed. Then adjust spring tension to get desired RPM.
majorlucas
PostPosted: Thu May 08, 2014 12:54 pm    Post subject: Re: 445 Governor Reply to specific post Reply with quote
Thank you! That seems like a much better way than simply guessing whether to lengthen or shorten it!
I'll let you know how we do!
Marty
Captainhookerus
PostPosted: Fri May 09, 2014 12:02 pm    Post subject: Re: 445 Governor Reply to specific post Reply with quote
Marty after reading my post I left out to also hold the carb shaft in wide open position while adjusting rod length.
majorlucas
PostPosted: Fri May 09, 2014 6:15 pm    Post subject: Re: 445 Governor Reply to specific post Reply with quote
Following your guidance, she is running better now. Lots more power, but still a little weak. I need to put an accurate tach on it to see what RPM she is set for.
At least I am able to get a little work out of her now!
Thanks!
Post new topic    Yesterday's Tractors Forum Index -> Minneapolis Moline All times are GMT - 8 Hours
