Author |
Message |
Underdog Moline Regular
Posted: Thu May 08, 2014 5:40 pm Post subject: mounted corn picker |
Any interest or what might it be worth? Lady said it was on a R Moline
Back to top |
Ollie Oliver Regular
Posted: Fri May 09, 2014 4:42 am Post subject: Re: mounted corn picker |
It's an Oliver built 74-H. Not sure what Moline's number for it was. Where is it located? I would say between $500 and $1000 depending upon the mechanical shape. I don't know, that seems to be an awful big picker to be on an r Moline. Most were made for the Oliver 1650-1850's etc. |
Back to top |
MM diesel Long Time User
Posted: Fri May 09, 2014 7:35 am Post subject: Re: mounted corn picker |
I am also curious about the location. There pickers designed to fit on the Moline M5, UB, or 445. This picker would be too big for an R Moline.
Michael Moeller
Waco, Tx
mmdieselpuller@yahoo.com |
Back to top |
TripleLPaints Guest
Posted: Fri May 09, 2014 10:00 am Post subject: Re: mounted corn picker |
This picker was likely made to fit U302, M670, and several later model Oliver tractors from 770's on up. This style was an Oliver 74H that was painted MM yellow. Could go on alot of different tractors tho. I tried buying one off a Farmall M a few years ago. The picker that fit the M5 and 4 Star was the SK "Rock and Roll" picker you backed underneath. The ones that fit the UB were "RJ" pickers that were two piece. |
Back to top |
Alan K Tractor Guru
Posted: Fri May 09, 2014 10:56 am Post subject: Re: mounted corn picker |
Maybe they found an R MM under it (lol). |
Back to top |
JAKFarms Regular
Posted: Fri May 09, 2014 11:55 am Post subject: Re: mounted corn picker |
Go to YouTube.com and type in Minneapolis Moline Picker at Walnut, Illinois and there is similar picker mounted on a M670 Super and a few other videos of same. |
Back to top |
maj-mm Regular
Posted: Sat May 10, 2014 6:49 am Post subject: Re: mounted corn picker |
Yes this is an Oliver picker. MM # is H210. Too large for an R. Would fit M5, M602,M670, M670 Super, as well as competitive tractors. |
Back to top |
gtractorfan Tractor Guru
Joined: 26 Sep 2011 Posts: 5823 Location: Van Wert, Ohio
Posted: Sat May 10, 2014 12:19 pm Post subject: Re: mounted corn picker |
That 670 and mounted picker scoot right along! If it was mine I'd think about painting it. |
Back to top |
MM Turbo Regular
Posted: Sat May 10, 2014 3:01 pm Post subject: Re: mounted corn picker |
Yes I am interested want to know price and location. Thanks Grant |
Back to top |
Posted: Tue May 13, 2014 8:42 am Post subject: Re: mounted corn picker |
Lady said it was on a R she used to run and the R is still there i couldnt find a S/N or tag to say who or what it was she is located in Southern Wisconsin if you are truely intrested please email me at plhawk@charter.net and we can go from there |
Back to top |
Alvin 41 New User
Posted: Thu Oct 04, 2018 6:15 pm Post subject: Re: mounted corn picker |
TripleLPaints wrote: | (quoted from post at 11:00:15 05/09/14) This picker was likely made to fit U302, M670, and several later model Oliver tractors from 770's on up. This style was an Oliver 74H that was painted MM yellow. Could go on alot of different tractors tho. I tried buying one off a Farmall M a few years ago. The picker that fit the M5 and 4 Star was the SK "Rock and Roll" picker you backed underneath. The ones that fit the UB were "RJ" pickers that were two piece. |
The SK "Rock & Roll" was probably easiest picker to mount, ever.Simply back under ,roll down and hook up 3-pt and pto. 3-pt raised picker. Had medium capacity. |
Back to top |
