sickle bar mower, what am I missing?
Kevin in Iowa
PostPosted: Mon May 26, 2014 8:54 am    Post subject: sickle bar mower, what am I missing? Reply to specific post Reply with quote
So I've got this Vermeer Sickle bar mower (model 678). I'm trying to hook it up to my 830 Case, every time I lift it it just moves over to the left and the pointy arm thing (part of the mower)that, from what I understand, it suppose to stay under the lower arm of my 3-point, just goes over my lower 3-point arm. Is there an adjustment on it? or do I need a chain or something to pull it over to the right? Where would the chain hook up to? I've tried to attach a couple of pictures. Thanks.
Kevin in Iowa
PostPosted: Mon May 26, 2014 9:01 am    Post subject: Re: sickle bar mower, what am I missing? Reply to specific post Reply with quote
here is a different look.
DKase
PostPosted: Mon May 26, 2014 9:22 am    Post subject: Re: sickle bar mower, what am I missing? Reply to specific post Reply with quote
Start by turning your sway blocks around so there is not so much side slop.
Kevin in Iowa
PostPosted: Mon May 26, 2014 9:49 am    Post subject: Re: sickle bar mower, what am I missing? Reply to specific post Reply with quote
Yes after I posted that I went back out and did that very thing. Gonna try it here in a minute.
maxwell99
PostPosted: Mon May 26, 2014 3:16 pm    Post subject: Re: sickle bar mower, what am I missing? Reply to specific post Reply with quote
kevin,
odd just how much your mower looks like my MF #32 mower, mine has the pitman, but the frame looks much like yours. I use my mower on a 1957 TO-35 Ferguson tractor.
my mower uses a stabilizer arm or bar that runs from under the right side axle bracket, back to the right side hitch pin.
this stabilizer bar keeps the mower positioned solid, so it can move up and down, but not side to side.
the casting with the, as you say (pointy thing) on the left side, that fits under the left side lift arm,
when you lift the mower, with the cutter bar in the down position, this hook device along with its associated rods, etc: will lift up the end of your cutter bar.
old mower works pretty good,
mine has a similar break away device as yours, but my mower is much older than yours, so you have many updated features.
mine was bought new in about 1960.
I can not leave the hitch bar on the tractor when the mower is attached, you do not want the pto shaft to hit the hitch bar!!!!!
