Author |
Message |
Larkin Guest
Posted: Wed Jun 04, 2014 2:12 pm Post subject: can my case 801 handle... |
Im farming alfalfa with my case 801b. Always contracted cutting/bailing.
Can I run a gehl 1460 4x5 800 pound rounds?
Will my hydraulic system be strong enough for tying/ ejecting
Also, I have tricycle set up. Bought a wide front to swap out, but wondering if I can just bail the alfafa tim grass mix with the tri.
Will the hay get crushed/wet? |
Back to top |
1031D Tractor Expert
Joined: 31 Jul 2004 Posts: 2407 Location: Southern Wisconsin
Posted: Wed Jun 04, 2014 2:39 pm Post subject: Re: can my case 801 handle... |
Switch to a wide front. When the hay dries running it over will knock the leaves off and that's the nutrients. I use my 530 to now and my 801 to bale, works good but you need to keeps the throttle up. |
Back to top |
Larkin Guest
Posted: Wed Jun 04, 2014 4:52 pm Post subject: Re: can my case 801 handle... |
Thats good info thanks.
The wide front I bought seems frozen up.
Ideas? |
Back to top |
Posted: Wed Jun 04, 2014 5:41 pm Post subject: Re: can my case 801 handle... |
Larkin wrote: | (quoted from post at 17:52:15 06/04/14) Thats good info thanks.
Ideas? |
Frozen as in wheels won't turn? Pivots froze? Or tubes won't slide? If the wheels won't turn there's needle bearings in the verticle spindles that may be dry or rusty. |
Back to top |
Larkin Guest
Posted: Wed Jun 04, 2014 6:10 pm Post subject: Re: can my case 801 handle... |
The wheels spin free. But I cant move the linkage, or the pivots/
tubes.
How should I attack it? |
Back to top |
Bret4207 Tractor Guru
Joined: 15 Jan 2005 Posts: 12046 Location: St Lawrence Valley, Northern NY
Posted: Thu Jun 05, 2014 3:16 am Post subject: Re: can my case 801 handle... |
I'd try getting some solvent and grease onto the spindles first. Dried grease responds very well to PB Blaster. Shoot it in with a grease gun. |
Back to top |
