Author |
Message |
connor9988 Tractor Expert
Posted: Fri Dec 19, 2014 3:56 pm Post subject: More work on the 300 |
Well tore into it a little more today. The lower portion of the fenders are rotted out but we should be able to save them. I removed the gauge cluster and it will need work. When the fire melted the battery it let the acid corrode the interior of the compartment including the cluster.Fingers crossed the glass protected the inside of the gauges.
one picture shows an interesting valve on the transmission. What originally went in that threaded port? Just the hydraulic return line?
Still looking for some tires for it. There are some cheaper ones for sale in Des Moines that I'm interested in.
Back to top |
chuck machinist Tractor Guru
Posted: Fri Dec 19, 2014 4:18 pm Post subject: Re: More work on the 300 |
connor9988 wrote: | (quoted from post at 00:56:11 12/20/14) Well tore into it a little more today. The lower portion of the fenders are rotted out but we should be able to save them. I removed the gauge cluster and it will need work. When the fire melted the battery it let the acid corrode the interior of the compartment including the cluster.Fingers crossed the glass protected the inside of the gauges.
 | I am glad to see that you have jumped into this resto/ You will spend more than you want to, but you will have great stories to tell and one fine tractor to show! Chuck |
Back to top |
C. Amick Tractor Expert
Joined: 05 Mar 2009 Posts: 2401 Location: Wytheville, VA
Posted: Fri Dec 19, 2014 4:37 pm Post subject: Re: More work on the 300 |
My 300 doesn't have a gauge cluster anymore. Someone pop riveted a piece of sheet metal over the cluster opening and cut holes in it to accommodate individual gauges. It looks pretty good. No tachometer or fuel level gauge though. |
Back to top |
Adirondack case guy Tractor Guru
Posted: Fri Dec 19, 2014 5:34 pm Post subject: Re: More work on the 300 |
I have a repairable gauge cluster that You can have for $30 bucks, plus shopping. e-mail open for pics and details.
Loren |
Back to top |
Joe (Wa) Tractor Expert
Posted: Fri Dec 19, 2014 5:55 pm Post subject: Re: More work on the 300 |
That is a selector valve mounted in the Eagle hitch hydraulic line. It would be used to supply hydraulic supply and return for remote single acting cylinder(s).
The valve simply selects the Eagle hitch OR a remote cylinder system for operation. This is some times used to operate the lift cylinders on a front loader.
Joe |
Back to top |
01gentdc Tractor Expert
Posted: Sat Dec 20, 2014 6:00 am Post subject: Re: More work on the 300 |
He would be better off finding a replacement for sure Loren ,,, They mite have one at Ruscha ,, too ,, |
Back to top |
oldmisterbill Regular
Joined: 12 Jan 2011 Posts: 482 Location: Wagoner,Oklahoma
Posted: Sat Dec 20, 2014 7:19 am Post subject: Re: More work on the 300 |
Well while we're on the subject of gauge clusters - I could use a repairable one too. I have 2 that only have Big holes where the gauges were. |
Back to top |
Posted: Sat Dec 20, 2014 9:45 am Post subject: Re: More work on the 300 |
ACG I might have to take you up on that offer. |
Back to top |
Posted: Thu Feb 12, 2015 1:32 pm Post subject: Re: More work on the 300 |
[quote="Adirondack case guy"](reply to post at 18:34:23 12/19/14) [/quote
So is the gauge cluster sold or could it be purchased?
Thanks Mr Bill
Last edited by oldmisterbill on Thu Feb 12, 2015 1:38 pm; edited 2 times in total |
Back to top |
