Author |
Message |
tluchterhandt Regular
Posted: Sun Jan 18, 2015 3:19 pm Post subject: Case 830CK Dual Remotes Trouble |
I've got a Case 830 CK that is having trouble with the top left hydraulic remote. The tractor has 2 remotes on top and 2 on the bottom. The inner lever controls the 2 remotes on the bottom. Moving the lever rearward pressurized the lower right coupling, moving the inner lever forward pressurizes the lower left.
The lower right operates as it should, but the lower left if I move the lever as it should be moved, loads up that side and seems to over pressurize and the cylinder won't move. But if I move it very slowly it will move the cylinder at a very slow rate. Pick up the pace and it loads up again. I have to wait a few seconds after it loads up for it to operate from either right or left. Any suggestions on what to look into? |
Back to top |
Adirondack case guy Tractor Guru
Posted: Sun Jan 18, 2015 3:46 pm Post subject: Re: Case 830CK Dual Remotes Trouble |
First thing I would do is check/change your male and female couplings. One or both may not be opening enough to allow full flow.
Loren |
Back to top |
Posted: Sun Jan 18, 2015 4:30 pm Post subject: Re: Case 830CK Dual Remotes Trouble |
Adirondack case guy wrote: | (quoted from post at 00:46:17 01/19/15) First thing I would do is check/change your male and female couplings. One or both may not be opening enough to allow full flow.
Loren |
Wow! I hadn't thought about that, thank you! I've been wanting to change them out from the vintage Case females on the tractor to standard Pioneer fittings anyways. I suppose now would be as good of time as any to do that.
Do you know if I will need thread adapters to change out to Pioneer? And if I do where they are available?
Thanks! |
Back to top |
Posted: Sun Jan 18, 2015 6:24 pm Post subject: Re: Case 830CK Dual Remotes Trouble |
Yes you will need adapters. If TSC, or your friendly CNH dealer doesn't have them, you can go to a place that makes hyd hoses and have the hose ends cut off and std 1/2" npt male ends put on for the pioneer couplings.
Loren |
Back to top |
casecollectorsc Tractor Guru
Posted: Sun Jan 18, 2015 6:40 pm Post subject: Re: Case 830CK Dual Remotes Trouble |
You can also buy adapters to go from pioneer to the Case female ends on the tractor. Case ends are a good coupler, I've never had bother with them and I do use the adapters. Easier than changing hoses, etc. |
Back to top |
Posted: Sun Jan 18, 2015 7:33 pm Post subject: Re: Case 830CK Dual Remotes Trouble |
If I'm not mistaken the fittings the hoses connect to on the tractor are 1/2" flare, I'm in the house now but I think the hose has the female coupler at the end, then goes into hose then switches to metal tube before the 1/2" flare nut. Will the hydraulic s shop be able to just make up the hoses new to fit on the tractor and ends for the pioneer fittings?
Or is that what you meant? |
Back to top |
Posted: Sun Jan 18, 2015 8:24 pm Post subject: Re: Case 830CK Dual Remotes Trouble |
If you are determined to use pioneer couplers instead of the Case couplers, Case-IH used to have a adapter to go from the fine thread to coarse thread to use different couplers. Don't know if they are available anymore. |
Back to top |
Posted: Sun Jan 18, 2015 8:33 pm Post subject: Re: Case 830CK Dual Remotes Trouble |
casecollectorsc wrote: | (quoted from post at 05:24:15 01/19/15) If you are determined to use pioneer couplers instead of the Case couplers, Case-IH used to have a adapter to go from the fine thread to coarse thread to use different couplers. Don't know if they are available anymore. |
Thanks I'll check with the dealer then. I was just wondering about changing out complete with hoses, because I have one hose that is bad, so thought I'd just swap it all out. And yes, I'm determined to go pioneer. |
Back to top |
Case Nutty 1660 Tractor Guru
Posted: Mon Jan 19, 2015 1:24 am Post subject: Re: Case 830CK Dual Remotes Trouble |
have new hoses made with 1/2" male pipe for the new Pioneers to screw on (and yes the fittings out of the control valve are standard fittings),, the kits from CASE were almost a 100.00 each the last time I bought them,,, and that was years ago, even though it is not factory I change the one I use most to Pioneers as well |
Back to top |
Posted: Mon Jan 19, 2015 5:41 am Post subject: Re: Case 830CK Dual Remotes Trouble |
Case Nutty 1660 wrote: | (quoted from post at 10:24:16 01/19/15) have new hoses made with 1/2" male pipe for the new Pioneers to screw on (and yes the fittings out of the control valve are standard fittings),, the kits from CASE were almost a 100.00 each the last time I bought them,,, and that was years ago, even though it is not factory I change the one I use most to Pioneers as well |
Yeah, some of the original parts can be pricey. Thanks for the info.
Another thing I wanted to throw out there is....
Do you guys have problems with pressure built up at the female coupler on the tractor, making it impossible to plug into it with the male coupling? And how do you work around that? |
Back to top |
Posted: Mon Jan 19, 2015 5:50 am Post subject: Re: Case 830CK Dual Remotes Trouble |
standing at the rear of the tractor you can "bump" the hyd control at the valve and release pressure,, or even easier is to shut off the tractor and work both controls each direction several times, I have done it so long I can do it easy with it running, you can also install couple under pressure Pioneer couplers, they cost more but will couple under pressure most times |
Back to top |
Posted: Mon Jan 19, 2015 6:00 am Post subject: Re: Case 830CK Dual Remotes Trouble |
Good info! Thanks! And when you say "bump at the valve" are you meaning actually at the valve and not the levers next to the fender? I've tried doing it at the levers and was not successful. But, I don't think I've tried it with the engine off. I like the idea of the pioneer couplers you just mentioned too! |
Back to top |
Posted: Mon Jan 19, 2015 6:17 am Post subject: Re: Case 830CK Dual Remotes Trouble |
at the valve you have better control to just 'bump" it enough to relieve the pressure,, start with shutting it of first,, all the hook up issues go away as long as you did not leave the implement lines pressured when you unplugged them,,,, this is a good time to shut off and work the levers as well to relieve pressure before you unhook |
Back to top |
Posted: Mon Jan 19, 2015 7:04 pm Post subject: Re: Case 830CK Dual Remotes Trouble |
Understood, thanks again. Now all I need is some time off work so I can remove the hose assemblies and take them to the hydraulic shop.
I'll let ya, ll know how it goes. |
Back to top |
John Saeli Tractor Guru
Posted: Tue Jan 20, 2015 6:56 am Post subject: Re: Case 830CK Dual Remotes Trouble |
Yes. still available. |
Back to top |
