transmission gasket 550 oliver
hankscott294
PostPosted: Mon Jun 08, 2015 7:37 am    Post subject: transmission gasket 550 oliver Reply to specific post Reply with quote
is there anyone who sells transmission gasket for 550 housing to hydraulic housing?
bison
PostPosted: Mon Jun 08, 2015 11:09 am    Post subject: Re: transmission gasket 550 oliver Reply to specific post Reply with quote
Way cheaper to buy a sheet of gasket material and make your own.
An alternate way to replace a gasket is to clean both mating surfaces with brakeclean and draw a single 3/16 to 1/8" bead of black RTV silicone in the center of the rail and surrounding all bolt holes with a little less and bolt the 2 together hand tight, wait an hour and torque to specs, let it cure overnight before exposing it to oil.
garanteed never to leak again.
Problem with using silicone is that people use way to much which results in most of it ending up inside a tranny or engine where it can cause problems.
A little goes a long way.
oliver1755
PostPosted: Mon Jun 08, 2015 11:11 am    Post subject: Re: transmission gasket 550 oliver Reply to specific post Reply with quote
Jerry at Ag Parts First has them. 330-264-9720. It takes two of them, one under and one above the pan for the hydraulic system.
lamimartin
PostPosted: Fri Jun 12, 2015 3:16 am    Post subject: Re: transmission gasket 550 oliver Reply to specific post Reply with quote
hankscott294 wrote:
(quoted from post at 11:37:46 06/08/15) is there anyone who sells transmission gasket for 550 housing to hydraulic housing?
Gaskets are available at Agco dealers parts depatrments. I would not take a chance with such critical gaskets because a failure would cost a lot to redo. The hydraulic system module upgrade is a labour intensive repair, with heavy weight lifting Laughing
mopardude318
PostPosted: Thu Feb 08, 2018 9:21 am    Post subject: Re: transmission gasket 550 oliver Reply to specific post Reply with quote
lamimartin wrote:
(quoted from post at 04:16:43 06/12/15)
do you know the part number for this gasket?
90 Percent Retired
PostPosted: Thu Feb 08, 2018 5:17 pm    Post subject: Re: transmission gasket 550 oliver Reply to specific post Reply with quote
mopardude318 wrote:
(quoted from post at 13:21:43 02/08/1Cool
Agco part # E2003 gasket, after tractor S/N 6050
mopardude318
PostPosted: Sat Feb 10, 2018 10:38 am    Post subject: Re: transmission gasket 550 oliver Reply to specific post Reply with quote
90 Percent Retired wrote:
(quoted from post at 18:17:53 02/08/1Cool
thank you. I also found it from here as well.
http://agpartsfirstllc.mybigcommerce.com/hydraulic-housing-gasket-e2003/
