520 coil wiring with a Pertronix
PushnFords
PostPosted: Sat Jun 20, 2015 5:22 am    Post subject: 520 coil wiring with a Pertronix Reply to specific post Reply with quote
I thought I posted this question a few days ago so my apologies if it is a duplicate...I can't find the other post.
Installing a new Brillman wiring harness in a 520 along with a Pertronix module. The wiring harness has a BROWN wire coming from the MAG/GRND terminal on the ignition switch to the (-) terminal of the coil. There is also a GREEN wire coming from the resister to the (-) terminal of the coil. I don't have the paperwork in front of me but the (+) coil terminal connects to...the ignition switch somewhere I think. The Pertronix module directions appear to say that the GREEN wire needs unhooked & hooked to one of the Pertronix wires while the other Pertronix wire connects to the coil (-) terminal. It doesn't say what to do with the BROWN wire but does say that there should only be two wires total going to the coil. What do I do with the BROWN wire?
John Deere D
PostPosted: Sat Jun 20, 2015 7:15 am    Post subject: Re: 520 coil wiring with a Pertronix Reply to specific post Reply with quote
Original wiring diagram.
Lee B
PostPosted: Sat Jun 20, 2015 11:18 am    Post subject: Re: 520 coil wiring with a Pertronix Reply to specific post Reply with quote
Tape it up, it is not needed.
Diagrams below show positive ground (thanks John Deere D), did you purchase a positive ground EI unit? It's important to match your ground system (positive or negative) with the EI unit used.
PushnFords
PostPosted: Sun Jun 28, 2015 8:28 pm    Post subject: Re: 520 coil wiring with a Pertronix Reply to specific post Reply with quote
Thank you!
PushnFords
PostPosted: Sun Jun 28, 2015 8:29 pm    Post subject: Re: 520 coil wiring with a Pertronix Reply to specific post Reply with quote
Yes I bought the positive ground EI unit. Getting anxious to get it assembled & try to fire it up!
