John Deere 4010 wiring diagram?
NoelC
PostPosted: Sat Aug 29, 2015 5:49 am    Post subject: John Deere 4010 wiring diagram? Reply to specific post Reply with quote
Does anybody happen to know where I can find a wiring diagram for a 4010? Can't get it
to turn over. Tested the starter, replaced the solenoid, replaced the ignition switch,
Checked the batteries. Suspect it must be a wiring problem.
buickanddeere
PostPosted: Sat Aug 29, 2015 7:26 am    Post subject: Re: John Deere 4010 wiring diagram? Reply to specific post Reply with quote
Given that the tractor is approaching 55 years old. It's time to consider that the old wiring harness is "done". Age, vibration, exposure to dust, dirt, mud, manure, oil, vibration and rodents have taken their toll.
I have used http://www.wiringharnesses.com/ and they are the best value for the $$$.
Better than having a tractor that won't start or bursts into flame.
This would also be the time to consider the 12V conversion.
Tx Jim
PostPosted: Sat Aug 29, 2015 8:29 am    Post subject: Re: John Deere 4010 wiring diagram? Reply to specific post Reply with quote
I'd suggest to check operation or lack of the neutral start switch(parts key 12) under cowling in frt of gearshift control lever
coonie minnie
PostPosted: Sat Aug 29, 2015 9:09 am    Post subject: Re: John Deere 4010 wiring diagram? Reply to specific post Reply with quote
I would suggest you check the function of the neutral start switch.... and that the harness is atatched to it. Look behind the right hand battery.
coonie minnie
PostPosted: Sat Aug 29, 2015 9:11 am    Post subject: Re: John Deere 4010 wiring diagram? Reply to specific post Reply with quote
And it looks like Jim beat me to the answer. It's behind the battery on a 4020... not sure on the 4010. I assumed the same.
NoelC
PostPosted: Sat Aug 29, 2015 9:19 am    Post subject: Re: John Deere 4010 wiring diagram? Reply to specific post Reply with quote
My father's tractor, I'm relaying messages to him. He doesn't think it has a neutral start switch, it used to turn over while in gear, had a 4020 with one. I'll tell him where to look.
Tx Jim
PostPosted: Sat Aug 29, 2015 9:27 am    Post subject: Re: John Deere 4010 wiring diagram? Reply to specific post Reply with quote
Check all 4 battery post connections for cleanliness & tightness.
NoelC
PostPosted: Sat Aug 29, 2015 9:35 am    Post subject: Re: John Deere 4010 wiring diagram? Reply to specific post Reply with quote
He has. Took the batteries out, charged one, replaced the other with a new one.
buickanddeere
PostPosted: Sun Aug 30, 2015 4:46 pm    Post subject: Re: John Deere 4010 wiring diagram? Reply to specific post Reply with quote
Mis-matched batteries can be a factor causing battery explosions.
Tx Jim
PostPosted: Mon Aug 31, 2015 2:39 am    Post subject: Re: John Deere 4010 wiring diagram? Reply to specific post Reply with quote
buickanddeere wrote:
(quoted from post at 19:46:57 08/30/15)
b&d
Please explain your "mis-matched" battery theory??
I've always heard in 24 volt system that new 12 volt batt installed with old 12 volt would draw new battery output down to equal old battery output but I never witnessed any explode except where "internal or external sparks" existed.
buickanddeere
PostPosted: Mon Aug 31, 2015 6:10 am    Post subject: Re: John Deere 4010 wiring diagram? Reply to specific post Reply with quote
Tx Jim wrote:
(quoted from post at 06:39:17 08/31/15)
b&d
It's not a theory . The stronger battery can push the weakest cell on the weak battery into reversal. That causes boiling and gassing vast amounts of hydrogen and oxygen. Add ignition source such as a failing internal link in the battery and BOOM.
Tx Jim
PostPosted: Mon Aug 31, 2015 8:16 am    Post subject: Re: John Deere 4010 wiring diagram? Reply to specific post Reply with quote
(quoted from post at 09:10:21
Failing internal link in a battery will cause a ""BOOM"" without the aid of a new battery attached to it.
Mike Aylward
PostPosted: Mon Aug 31, 2015 8:28 am    Post subject: Re: John Deere 4010 wiring diagram? Reply to specific post Reply with quote
On a 4010 the neutral safety start switch is just ahead of the shifter assembly under the right hand side of the dash cowling. Mike
