600 series ground strap
martyh
PostPosted: Tue Sep 08, 2015 1:15 pm    Post subject: 600 series ground strap Reply to specific post Reply with quote
My 640 has a blue wire from negative battery post to a bolt on the hydraulic pump. Obviously this is not correct. Can someone tell me where the original 11 inch braided ground strap is supposed to be bolted?
old
PostPosted: Tue Sep 08, 2015 2:33 pm    Post subject: Re: 600 series ground strap Reply to specific post Reply with quote
If I remember right it would have been the bolt that holds the battery box on
Kirk-NJ
PostPosted: Wed Sep 09, 2015 1:29 am    Post subject: Re: 600 series ground strap Reply to specific post Reply with quote
I agree with old, battery bolt box on the steering column.
Kirk
RickB
PostPosted: Wed Sep 09, 2015 1:33 am    Post subject: Re: 600 series ground strap Reply to specific post Reply with quote
That's correct, but it is a poor location from a functionality standpoint. Too many joints between parts for a good electrical ground path to the starter. I like my grounds right at a starter mount bolt.
martyh
PostPosted: Wed Sep 09, 2015 3:18 am    Post subject: Re: 600 series ground strap Reply to specific post Reply with quote
If it'll function where it was supposed to go originally, that's where I'm going to go. Right now it has a 2ft long autoparts store cable in BLUE snaking around from ground and eventually ending up on a bolt at the hydraulic pump. I've ordered the original 11 inch bare braided cable and will find out just how much corrosion there is between all of the components. lol.
old
PostPosted: Wed Sep 09, 2015 8:24 am    Post subject: Re: 600 series ground strap Reply to specific post Reply with quote
I agree with you and when I can that is right where I ground one since the closer you get tot the starter the better it is grounded
