Who makes 3pt hitches for 48 H
Goto page 1, 2  Next
Farmallb
PostPosted: Mon Mar 14, 2016 1:29 pm    Post subject: Who makes 3pt hitches for 48 H Reply to specific post Reply with quote
They used to be advertised in Tractor catalogs, but I cant find them now.
Brendon-KS
PostPosted: Mon Mar 14, 2016 3:17 pm    Post subject: Re: Who makes 3pt hitches for 48 H Reply to specific post Reply with quote
Worksaver makes one. On their website it is listed under "International Harvester Tractors" instead of under the "Farmall Tractor" menu.
fastfarmall
PostPosted: Mon Mar 14, 2016 3:35 pm    Post subject: Re: Who makes 3pt hitches for 48 H Reply to specific post Reply with quote
I think Steiners has them now!!
Farmallb
PostPosted: Mon Mar 14, 2016 4:28 pm    Post subject: Re: Who makes 3pt hitches for 48 H Reply to specific post Reply with quote
Stieners does have them. OUCH, $1000. That aint happening.
DeltaRed
PostPosted: Mon Mar 14, 2016 5:29 pm    Post subject: Re: Who makes 3pt hitches for 48 H Reply to specific post Reply with quote
Just make your own. If you can weld/fabricate,no problem. Or get a buddy who can weld and 'draft' him for a weekend.Use top links for the 'leveling cranks',a chunk of 2" solid shaft for the rock shaft,pipe for the pivot 'bearings'. I made several 3 pts,from H to 560.For a couple hundred bucks(less if you use 'used' steel,useing your own cylinder) and sonme time/labor. Done deal.
FBH44
PostPosted: Mon Mar 14, 2016 5:33 pm    Post subject: Re: Who makes 3pt hitches for 48 H Reply to specific post Reply with quote
I bought an economical 3-point many years ago and after plowing, I twisted / bent the 2" circular shaft. Had to have it taken apart and redone. I'd recommend a hardened steel alloy steel shaft of some sort.
Farmallb
PostPosted: Mon Mar 14, 2016 6:40 pm    Post subject: Re: Who makes 3pt hitches for 48 H Reply to specific post Reply with quote
DR, I can weld good enough. BUT, I have no idea what a rock shaft is, OR where it goes,
Are what you call the pivot bearings, the inner and outer ends of the arms?
I Only want to use it on a post hole digger.
Where does the cylinder mount at? I have a 2 way cylinder. I think it can be used one way. I thought about making it. Got on U tubes, but didn"t see anything.
DeltaRed
PostPosted: Mon Mar 14, 2016 8:48 pm    Post subject: Re: Who makes 3pt hitches for 48 H Reply to specific post Reply with quote
The 'rockshaft' is the big round shaft that pivots.It doesthe acctual work of lifting.Look up somr three points on the internet. You will get an idea of how they are made.
river9072
PostPosted: Tue Mar 15, 2016 1:48 am    Post subject: Re: Who makes 3pt hitches for 48 H Reply to specific post Reply with quote
I have a real nice one,was on an m,but I think it would fit an h,not sure where your located,Im in nw IL.
AlinMO
PostPosted: Tue Mar 15, 2016 4:03 am    Post subject: Re: Who makes 3pt hitches for 48 H Reply to specific post Reply with quote
Try this link
http://www.tonystractors.com/ih3ph.htm
rustyfarmall
PostPosted: Tue Mar 15, 2016 6:19 am    Post subject: Re: Who makes 3pt hitches for 48 H Reply to specific post Reply with quote
By the time you accumulate all the steel and hydraulic cylinders to "do it yourself", $1,000 will look pretty cheap.
ss55
PostPosted: Tue Mar 15, 2016 8:47 am    Post subject: Re: Who makes 3pt hitches for 48 H Reply to specific post Reply with quote
Saginaw County Tractor ( www.saginawcountytractor.com ) used to make nice 3 point hitches for older tractors. Maybe look for a used one?
Farmallb
PostPosted: Tue Mar 15, 2016 9:08 am    Post subject: Re: Who makes 3pt hitches for 48 H Reply to specific post Reply with quote
Im in NE Okla. What would you want for it?
river9072
PostPosted: Tue Mar 15, 2016 5:14 pm    Post subject: Re: Who makes 3pt hitches for 48 H Reply to specific post Reply with quote
i was thinking 325,i can send pics if your interested.
Farmallb
PostPosted: Tue Mar 15, 2016 6:53 pm    Post subject: Re: Who makes 3pt hitches for 48 H Reply to specific post Reply with quote
Any way you can send me your name and Ph#
Goto page 1, 2  Next
Page 1 of 2
