201 Diesel exhaust manifold
Rustytractorguy
PostPosted: Wed Mar 30, 2016 3:18 am    Post subject: 201 Diesel exhaust manifold Reply to specific post Reply with quote
Quick question, well 2 questions.
1) Those goofy little lock tab washers listed on the CNH parts site for the exhaust manifold bolts, does anyone use those or is there a more cost effective option. The dealer wants $2.15/ea. Not a lot of cash but if a regular lock washer works well then the cash is better off in my pocket.
2) What would be a good way to remove the exhaust manifold bolts without breaking them off? I haven't tried yet but I don't want to make a chore out of it if at all avoidable.
Ultradog MN
PostPosted: Wed Mar 30, 2016 4:09 am    Post subject: Re: 201 Diesel exhaust manifold Reply to specific post Reply with quote
The manifold bolts get really come out of
the head quite easily. I've had a couple
that the heads were so corroded away that a
wrench wouldn't fit on them anymore so I cut
them off with a grinder. But the bolts
always unscrewed from the head with no
problem.
As for the lock washers, wow I wish I could
get those kind of prices.
Just put ordinary lock washers on and forget
about them.
Rustytractorguy
PostPosted: Wed Mar 30, 2016 4:29 am    Post subject: Re: 201 Diesel exhaust manifold Reply to specific post Reply with quote
Thanks for the advise! I hope my bolts too come out easily, when I get around to it.
souNdguy
PostPosted: Wed Mar 30, 2016 9:30 am    Post subject: Re: 201 Diesel exhaust manifold Reply to specific post Reply with quote
agree with UD.
generic lock washers fine.
as for the head and bolts /studs.
remember.. the head is soft.. studs or bolts were probably grade 5-8
hit them with penetrant, use a drift and give a smack square on the head with a drilling hammer.
they should come off.
if they act stuck, don't use a long hard pull with a breaker bar, but instead use an impact wrench.. set it soft and let it hammer lightly, then gradually turn the air up. Sometimes you can tighten a second, spray more penetrant, then loosen.
RodinNS
PostPosted: Thu Mar 31, 2016 6:17 am    Post subject: Re: 201 Diesel exhaust manifold Reply to specific post Reply with quote
I always use the exhaust bolt lock tabs.... but then again, I always buy the full upper gasket sets which are about the same money as buying
a couple gaskets individually... and the locks are in the set.
Rod
Rustytractorguy
PostPosted: Thu Mar 31, 2016 8:48 am    Post subject: Re: 201 Diesel exhaust manifold Reply to specific post Reply with quote
Do you anti-seize on reinstall? I'd venture to say yes.
